Question about Mito Car Audio & Video
Cagiva mito engine trouble i split my engine in half to put a new set of main bearings in and an o ring droped out i havent a clue where it goes
  • 3741 Answers
SOURCE: cagiva solenoid
1. Battery Voltage. - Key off: between 12 - 13VDC.
2. Key off Amp Draw - At the main fuse: < (less than) 1ADC
3. Key on Amp Draw - At the main fuse: Results will vary because of different loads.
*Note - DO NOT START THE BIKE WITH YOUR METER IN PLACE OF THE MAIN FUSE! Also, if you can not access the main fuse, put your positive meter lead on the red wire at the solenoid, and put your negative meter lead on the positive battery lead. This way you will be able to get your amperage readings AND let you start the bike without blowing your fuse.* Charging amperage should be at least 1 ADC
4. Break even speed - The RPM in which the charging voltage at the battery turns positive - Should be before Idle
5. Charging voltage at the battery - Between 13 - 15 VDC.
hope the above details help.thanks for using fixya.
Posted on Aug 28, 2009
Testimonial: "thanks alot was very helpful :)"
  • 12 Answers
SOURCE: my cbr was stolen about a week ago and i want to
well ive riden my cagiva ( the same as ur m8) 90 miles non stop with out overheating , just make sure u have enough anti freeze and dont ride it fast for a long tym at once
Posted on Feb 03, 2010
mwoodring1
  • 496 Answers
SOURCE: How easy is it to
how are you with taken things apart?? cause what you have a head of you is a job. NEVER just replace one part, you are already taken the whole thing apart might as will rebuild and make it right.
if you would like more help i'll be happy
Posted on May 23, 2011
markmayes66
  • 786 Answers
SOURCE: Toyota tercel 1988, engine knock. Replaced pistons rings and con rod brgs. Engine still has knock but not as survier. Has anybody changed main bearings with engine installed?
You will have to remove crank to replace and removing motor would be my suggestion...Would also suggest having the crank turned.......hope this info helps and good luck......please rate my post....
Posted on Aug 17, 2012
SOURCE: no start but electrics still work
How are you going with this issue? I too have same issue all electrics but no start. Not even turning over..
Posted on Mar 18, 2015
How much fork oil do i put in a 2000 cagiva mito
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Cagiva but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Fork Oil On Mito
APRILIA RS125 fork repair CAGIVA MITO BASIC MAINTENANCE FORKS SEAL...
http://www.carlsalter.com/pdfs/Cagiva_mito_ev%201994.pdf
Cagiva MITO EURO2 125 2004 parts OEM Motorparts
http://www.cagiva.nl/media/owner_manuals/?tx_motomondo_pi4%5Bmodel%5D=&tx_motomondo_pi4%5Byear%5D=-1&tx_motomondo_pi4%5Bmanual%5D=
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 05, 2013 | 2008 Cagiva Mito 125
Cagiva mito 125 carb settings
Hi, Anonymous tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicte balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. Here is how and where you compensate trouble:
1. Your air/fuel mixture screw manages your idle.
2.. Your slow speed jet manages 0-1/4 throttle opening.
3. Your jet needle c-clip position manages 1/4-3/4 throttle opening.
4. Your main jet manages 3/4-wide open throttle.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues. For more information about your issue, please visit the websites below. Good luck and have nice a day.
CAGIVA MITO 125
aprilia rs125 and cagiva mito basic maintenance 28mm carb strip d
May 18, 2012 | 2006 Cagiva Mito 125
Could anybody please tell me what the settings are for oil pump on a cagiva mito 125 r plate.
Hi, Sue I am sorry you can't find the first and best tool you ever bought for your Cagiva but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
oil pump setting
Cagiva Mito 125 settings are for oil pump Google Search
Feb 17, 2012 | 2006 Cagiva Mito 125
Cagiva mito engine locks up when clutch cover is fitted
Hi, Ben_bywater sorry you can't find the first and best tool you ever bought for your Cagiva despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
CAGIVA MITO 125
aprilia rs125 and cagiva mito basic maintenance clutch testing and assembly
Free Cagiva Motorcycle Service Manuals for download
http://www.oemmotorparts.com/oem2.asp?M=Cagiva
Nov 21, 2011 | 2000 Cagiva Mito 125 Evoluzione
Carb set up
Hi, Katymayjones tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. Here is how and where you compensate trouble:
CAGIVA MITO 125
Cagiva Mito idle problem
Aug 28, 2011 | 2006 Cagiva Mito 125
Cagiva mito starting problems
Hi, Martin_harri sorry you can't find the first and best tool you ever bought for your Cagiva despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.Cagiva Mito Starting problem
cagiva mito not starting
Sep 04, 2009 | 1991 Cagiva Mito 125 - Lawson
How to set up power vale for a cagiva mito
Hi, Tyson_row sorry you can't find the first and best tool you ever bought for your Cagiva despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Help Cagiva Mito Problem
Cagiva Mito powervalve
Aug 27, 2009 | 1994 Cagiva Mito 125 - Lawson
Car Audio & Video Logo
Top Mito Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Mito Car Audio and Video Expert? Answer questions, earn points and help others
