Question about Motorola Mobility RAZR V3x Cellular Phone
The keys won't work. is there a way to reboot it?
  • 13,433 Answers
Try taking out the battery while its powered on, wait a minute and place it back in and see if they work.
if you don't see anything wrong with the keys from the outside, its most likely a problem with the buttons inside or the mainboard is not working anymore, If you are in warranty get in touch with motorola to get it repaired or your dealer.
If you are outside of warranty, as this is most likely a hardware issue, not a setting, you can't turn the keys off like that. Without being able to look inside your phone from the other side of the world I suspect that the mainboard of the phone where the keys are would need to be replaced or repaired, this not worth replacing the mainboard in most cases, its somewhat like buying a new phone. So just instead by a new phone in that case or get it looked at by a local professional or a motorola service center to find the problem.
Again I very much suspect its a hardware issue and theres noting we can do about it.
Well, when you press on the keys, do you feel that something moves inside? does it click? like a button would get pressed inside?
If it doesn't, then the buttons could be stuck or the cover of the phone - the keypad is not reaching the button for some reason anymore - most likely the button is stuck or similiar.
Let me know how it goes.
Posted on Sep 11, 2009
Unlock keyboard n150
Have your shut down, unplugged, remove battery, plug in, rebooted? Try here for a User Manual: http://www.samsung.com/us/support/owners/product/NP-N130
Jul 03, 2013 | Samsung NP-N130-JA01US Netbook
Toughbook CF-53 Speakers won't work
Have you tried rebooting? In the Control Panel, select Sounds, select Speakers as default, remove headphones plug from jack.
May 24, 2013 | Computers & Internet
Touch screen won't work
same problem with me too.. i was told to reset the phone and it worked fine.:)
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.3.Use Vol+ key and Vol- key to move the cursor to "wipe cache partition" and press camera key to confirm it.
4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically.dont forget to backup important data to you sdcard.this will save your information.
Feb 15, 2013 | ZTE Warp
Screen won't unlock
Please try Hard Resetting the device and chck if that would work.1.Power off the phone.2.Press and hold Vol+ key and Power key simultaneously until several blue sentences appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.3.Use Vol+ key and Vol- key to move the cursor to "wipe data/factory reset" and press camera key to confirm it.4.There are many words "No" and one sentence "Yes -- delete all user data". Use Vol+ key and Vol- key to move the cursor to "Yes -- delete all user data". Press camera key to confim it.5.The phone will finish the reseting by itselft after about 10 seconds later and then the cursor will be on "reboot system now" and press camera key to confirm it. The phone will reboot automatically.There is no unlock and password any more after the phone is on.
Jan 14, 2013 | ZTE Warp
Zte score x500 muve music won't launch?
Try Hard Resetting the device and check if it works.1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.
2)When display press the Menu key at the bottom of the screen;3) Choose "Wipe data/factory reset" through volume key4) Press "Camera" key to confirm the above item5) Choose "YES...delete all user data"6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Dec 10, 2012 | ZTE Cell Phones
I broke my screen and I had it with vga to tv worked fine untill it went into safe mode now won't work
reboot your computer and run normal, then hit FN keys and hit the key that has a monitor picture..usually on the f1- f12 keys do it both at once it should send the signal to the tv
Dec 06, 2012 | Toshiba Computers & Internet
We put our Acer desktop to sleep last night and now the keyboard won't activate-no lights on function keys or anywhere else.
Have you tried disconnecting the power supply and battery for about a minute.Then reconect the battery and power and restart.Has worked for me
Oct 23, 2012 | Acer Power S285 PC Desktop
Cant access bios to change boot order to reuinstall windows 7
Boot the computer and watch the screen. It will tell you what key to hit to get into the Bios or System Setup. You have to hit the key when you see the message or it won't work and you will have to restart.
It also shows you which key to hit to change the Boot Sequence or Boot Order. But you have to hit the key when the message appears on the screen or it won't work and you'll have to reboot. This is a temporary 1 time change for the current boot cycle. When you change it in the Bios or System Setup it's a permanent change.
May 25, 2012 | Computers & Internet
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
Jul 24, 2011 | 2008 Jeep Cherokee Grand
Motorola Mobility RAZR V3x Cellular Phone Logo
13 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
