Question about Maxtor Hard Drive
My computer went bluescreen and did a physical memory dump. Then would not boot from C: again. BIOS sees the hard drive but thinks it is unformatted. chkdsk says 'volume appears to contain one or more unrecoverable problems'. Is there any hope?
  • 60 Answers
Many Computer repai places have the ability to pull your unbacked up date from that drive contact a local repair store to get pricing and also look into a new drive to be installed and re-install your windows and programs if you need someone to install them. (tip never save anything to your C drive install a second drive and save everything there) This is a good tip and I use it for our Video Editing Studio.
Cheers
Al
Posted on Sep 11, 2009
Blue screen error all the time
The 'blue screen of death' usually means a hardware/physical problem, probably with the hard-drive. Have you tried reinstalling/repairing windows? That usually works.
kc
Mar 28, 2011 | Computers & Internet
I have a Creative Live ! Optia AF Webcam. If i put the USB of the Webcam in the USB-Slot (1 of 4 USB-Slots and all tested), i get a Bluescreen Error and my Computer shuts down. Is my Webcam destroyed? The...
A bluescreen error is rarely a good sign, but sometimes it's fixable. Have you tried plugging the webcam into a different USB port? Also have you tried unplugging some unnecessary USB devices and then using the webcam? You may be draining too much power from the PSU with USB devices and the PC shuts down to prevent damage. Have you been able to test on a different computer to see if the problems happens there as well?
Mar 24, 2011 | Creative Labs WebCam Live!
Physical memory dump
Hmm... Well a Bluescreen is when your computer crashes, and (as you have found out) preforms a physical memory dump. This can be caused by multiple things. Such as bad drivers, PFN(page frame number) or problems with your memory. When a bluescreen event occurs, the is a technical information which has an error code that can be used to help find the problem. In order to fix this problem, you may have to remove any software, or hardware that you have recently installed. To uninstall software, you may need to boot in safe mode, which is where your computer starts up using the minimal amount of drivers needed, in order to try to prevent the computer from crashing.
Here are some useful websites (sorry, my hyperlink icon isn't working):
  • www.datarecovery.com.sg/data_recovery/hard_disk_symptons_blue_screen.htm
  • www.maximumpc.com/article/features/blue_screen_survival_guide
Feb 27, 2010 | Dell Dimension 8400 PC Desktop
17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • Feb 04, 2010 | X2Gen MG19MY 19" LCD Monitor
    No operating system found
    sounds like the hard drivemag-glass_10x10.gif has either taken a dump and is not working or maybe the connection to it has been lost. Either way I think you have hard drive problems. When booting keep an eye out for where the hard drives are detected and see if the computer sees the hard drive.
    Mar 29, 2009 | Computers & Internet
    Thinkpad 390x 2626, won't boot from cd drive
    Try pressing F12 at startup, you should get a boot option.
    Nov 19, 2008 | Computers & Internet
    My system display bluescreen and say physical memory dump then restart everyday minimium 5times
    there are some reesons for this blue screen,first check for error dump files in your system(hope you use windows OS),which may be stored to send error reports to Microsoft,second thing is your C: drive may be almost full,owing to many installed programs,third thing you may have low RAM memory.
    Oct 10, 2008 | Seagate 9w2874-500 200 GB Hard Drive
    Bad Hard Drive?
    By download a hard drive diagnostic program you can check if the hard drive is good or not.
    Here is one from seagate, Seatools:
    http://www.seagate.com/www/en-us/support/downloads/seatools
    Basically, you create a bootable cd or flopppy with the program and then boot to that media. The program will tell you if the hard drive is still good.
    Jun 13, 2008 | Sony VAIO VGC-V617G PC Desktop
    Maxtor Hard Drive Logo
    67 people viewed this question
    Top Maxtor Computers & Internet Experts
    Computer Links
    Rick Arnold
    terminalcon
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
