Question about HTC S740 Smartphone
My S 740 does not recocognize the headset as headset. Also it plays the sound via the headset speakter, microphone and keys are not working. Any idea? Thanks in advance. Regards, Jenne
Logitech speaker feedback
Feedback is a sharp, loud noise that can come through the earphones of a headset unexpectedly---it occurs when the headset is getting sound (feed) from someone else speaking or playing music into a microphone. This sound can create a dangerous situation for someone who is operating expensive equipment or flying a plane at the time since it can disable hearing temporarily.
If you experience feedback often, it could also lead to serious hearing problems.
Mic Too Close to the Speaker or Volume Too High
The main cause of a feedback sound in a headset is proximity to a speaker. If a person holding a microphone on the other end gets too close to a speaker, it creates a loop of re-amplified sound that results in the loud, screeching noise. When the volume on the other party's microphone is too high, it is more vulnerable to picking up unwanted noise and feedback from speakers and sound output devices in the room. So make sure that you ask the other party to turn down the microphone to a normal level and stay far from speakers. b> Two Microphones Gathering Same Sound b> When the other party places two microphones too close to each other, it could cause feedback. When positioned toward the sound source (such as a person speaking) the microphones will both pick up the same audio and compete with each other when creating the output of sound, causing a sharp noise in your headset. This problem, called acoustic phase interference, is resolved by simply ensuring that the other party uses one microphone at a time. Poor-Quality Headset or Microphone b> One common cause of feedback is simply a poor-quality headset or microphone. Most modern headsets and microphones have noise-canceling features that manage and kill feedback before it has a chance to occur. These noise-canceling headsets are essential for pilots and aviation crew members. If you hear sudden feedback that is strong enough to hurt your ears, the headset or microphone is simply not properly equipped to actively cancel that unwanted noise before it hits your ears. Buy a higher-quality noise-canceling headset to manage the feedback noise when you're going about your tasks. Hope this helps.
Dec 23, 2012 | Logitech Z623 Speaker System
Bought new dynex dx-740 earclip headset with microphone. earpiece works but computer not picking up microphone.
Have you installed the software for your headphone? Your computer might not pick up your device because it doesn't recognize the device.
Mar 06, 2011 | Dynex Earclip Headset with Noise-Canceling...
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for...
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Oct 15, 2010 | Plantronics Pulsar 590A Wireless Headset
MOTOROKR S9 has microphone but not sound with PS3
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks....
Jan 28, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Logitech ClearChatStyle Headset + Skype + Vista Premium Home
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Hope can help
Aug 15, 2009 | Logitech ClearChat Stereo Headset Headset
I think I need a driver for a Mikomi headset with mike.
mikomi head and mic set drivers for xp pro meed pls
Mar 18, 2009 | Audio Players & Recorders
Cannot use microphone.
Hi I have had a similar problem with a Mic, too things to try , first try it on a different appliance to rule out the appliance you are using, if it still doesn't work then it's most likely a short somewhere, tough to repair but worth a shot if you have the patience.
Hope this helps.
Dec 06, 2008 | Radio Communications
Sound and microphone problems
check for proper drivers for your sound card it will solve you problem....
Sep 14, 2008 | Dell Inspiron E1505 Notebook
AC-740 : No Manual
does it have 2 plugs one for mic and headset or sterio plug for mono head set mono mic u would need input on phone that can accept that kinda sterio input ok for both
Jan 28, 2008 | Cyber Acoustics AC-740 Headset
Microphone volume
I'm not 100% sure it's the microphone in your case, since I am experiencing the same problem right now with another microphone. I borrowed a working headset from my friend and it is not working either. My volume is up like yours and I can barely hear myself. I am updating the drivers soon and I'll let you know if that fixes it.
Oct 07, 2007 | Creative Labs HS-400 Headset
HTC S740 Smartphone Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
