Question about HP Compaq NC6400 Business Notebook
Hp power adapter short out - HP Compaq NC6400 Business Notebook
  • 22 Answers
EBay has power adapters for all kinds of laptops. Best prices I've found anywhere. Have purchased several for myself and other clients.
You'll pay to much are retailers for the same quality. Don't do that.
Just do a search on eBay for your computer and you will find a listing of all adapters that apply to your system.
Posted on Sep 12, 2009
  • 3 Answers
Well it could be one of two problem (1) if your computer is not charging up then the adapter might be bad, but try testing it on a friend computer to see if it work in their.(2) it your computer does come work when you plug in the adapter it might be a kill switch with mean the motherboard is death so when you plug it in it chips the adapter out
Posted on Sep 11, 2009
Power won't charge
If the power adapter is functional and the computer is running well with the adapter plugged into the wall; then the power cell has died. Most of the batteries have 6 cells inside and only one cell shorts and the entire battery will fail to work or take a charge.
Feb 21, 2014 | HEWLETT-PACKARD Hewlett Packard HP Slate...
My hp compaq 6910p laptop not on adapter is ok **** i plug in laptop no power on no any light on
Unplug adapter using cheap multimeter, check for voltage on the Plug the goes to laptop.. the plug should be producing 13+ volts ( not sure exactly of Spec, but it is located on the power pack itself. )
Your problem sounds to me like your power supply is shorting out .
Alternative problem is the charge circuit on the mainboard may need to be serviced. ( commonly replacing mainboard- some facilites can repair )
Jan 12, 2012 | HP Compaq 6910p Notebook PC PC Notebook
Accidently tried to change one of the ink cartridges while the printer was off. Now the printer won't turn on. It's a HP Photosmart C5280 all in one.Thanks
Removing/loading the cartridge are not related to powering section, check adapter voltage if its ok observe any spark generating while inserting the adapter pin in the printer socket if yes there is short in logic card, replace the logic(formatter) card..* very very rare cases if cartridge got short it will damage the logic card,result printer goes in dead condition.
Sep 25, 2011 | HP Photosmart C5280 Printer
HP Pavilion zv6000 power issue. My laptop fan kicks into high gear whenever the adapter is plugged in. Frequently it suddenly shuts off completely to keep itself from overheating. If I use battery-only...
the PC needs to be cleaned,every year or it will overheat.
lint packs up.
what is the ADAPTeR, we cant guess them. ever.
aH the AC power pack is the ADAPTER?
i bet the battery goes dead with no adapter right
so the acid test is this
no battery run on the adapter
if that fails, the adapte is wrong or dead. or weak
1: wrong size 65w or 100w. less never.
2: wrong voltage ,19vdc is correct for HP. not 12,
3: the jack on the mobo for 19v is cracked ,common on some
i never buy PC with this part , I buy Elitebooks that cure that horror.
what happens is you flex cable.
and the jack flexes and then the solder joint crack
all do, its one bad horror. (mine uses a anti crack flex cable inside)
http://www.ebay.com/itm/DC-POWER-JACK-IN-HP-ZD8000-ZV6000-COMPAQ-R4000-X6000-MOTHERBOARD-SOCKET-CHARGE-/271259462380?hash=item3f2852eaec:g:C8MAAOxy9LxSDsly
Aug 04, 2017 | HP Pavilion zv6000 Notebook
My HP PAillion ze2000 PC Notebook will not charge
I had this problem with my laptop and the way to solve it is.... guess!!
Get a new power cord!!
Dec 31, 2009 | HP Pavilion ze2000 Notebook
HP Compaq NX9420 Laptop Power supply shorted out replaced new Power supply purchased but Laptop will not power up suspect mother board shorted out also. Any suggestions
The DC Jack Will Need To Be Visibly Inspected, and Tested ..
Most Likely Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into.....
Though, if you experienced a power surge/dip or similar, You could have shorted out the motherboard....
Dec 01, 2009 | HP Computers & Internet
My hp pavilion dv2500 will not turn on at all. I can plug up the ac adapter and the blue light surrounding it comes on but it will not come on when I push the power button.
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Another possibility would be that there is a short circuit somewhere in the power circuitry on the motherboard.
Sep 20, 2009 | HP Pavilion dv2500t Notebook
Blank screen on the HP tx1000
I hear your complaint, but you haven't discribed the problem.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
These are the first steps to take to get to the root of the problem.
Jun 12, 2009 | HP Pavilion tx1000z Notebook
No power
start wit ha power reset, remove the battery, remove the ac adapter, hold the power button for 1 minute and then repalce the battery and ac adapter, if theres no go try it with just the ac adapter, sometimes the batteries short out. if all else fails its probably the mmobo and i suggest calling compaq for warranty support
Jan 23, 2009 | HP Compaq Presario V2000 Notebook
NO POWER/NO BLUE LIGHT
eww.... Probably it's something related witht power supply of the laptop....Contact hp.....
Jun 21, 2008 | Compaq Presario 700 470024-192 Notebook
HP Compaq NC6400 Business Notebook Logo
155 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
