Question about Whirlpool Duet GHW9150P Front Load Washer
F11 and DL failure codes
I am doing the same thing and praying before and after each use
    President:
  • 1,653 Answers
The F11 error indicates a communications error between the CCU (Central Control Unit) and the MCU (Motor Control Unit). Check the wiring harness and connections at both the CCU and MCU. Unplug them and check for corrosion on the terminals / pins, clean them if necessary then reconnect them securely. As there is a D11 error as well it indicates a problem with the door lock relay, faulty hall sensor, faulty CCU or faulty MCU. If you still have the problem then call in a repair man to fix it.
Posted on Sep 11, 2009
Washer stops and F11 code flashes
An F11 is a communication failure between the machines control board and the motor controller. Often you will also experience a 'DL' error associated with the F11 because when the washer fails, the door is still locked and when you restart the wash, the electronics will try and lock an already locked door. Either the control board or motor controller can cause this error along with a bad harness or loose connector, but the majority of the time it is the main control that is failing.
Dec 29, 2011 | KitchenAid KHWS01PMT Front Load Washer
What do the codes : F, F11, and Fdl mean when flashing on my whirlpool front load washer?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Below I give you some solutions picked from this site. There are five down para-wise You may find some very useful:
I had same error code F11 and DL.....I sprayed the door lock (inside) with WD40......so far works OK
I had the same F11/DL problem. I tighten the two screws on the door latch and it's working great. for now
Just some part numbers to help if you need to order parts. For the GHW9200LWO Washer (Sanitary Cycle Model)- the part number for the CCU (Microcomputer or main computer) is 8181924. The part number for the Motor Control Unit (MCU) is 8182706. I did a search for the part numbers and found the CCU for $79.90 shipping included - the same part from Whirlpool was $190 plus with shipping included. I put the CCU on and my washer works perfectly again. Hope this helps someone since I had such a hard time finding out the correct part numbers. Whirlpool first sent me the MCU even though I specifically told them it was not that part but the CCU.
DL is a door lock error. This is usually an indication of a bad door latch. F11 is a serial communications error from the Central Control Unit CCU (which is your main computer). If the door latch is defective it could be generating the communications error code as well. A defective CCU can also give the same symptoms, though. Before replacing any parts, however, double check all you connections to make sure you don't have any loose wires. The least expensive of the two possible solutions would be to replace the door latch (about $50). The CCU can run between $150 and $250. Hope this leads you in the right direction.
I wanna thank all of you for your input. I had the "DL F-11" code also. My washer would run 12 minutes and then stop with the annoying beep and error codes. After learning that the "DL" was the door lock, I decided to order the part online for 50 bucks. After I placed the order I decided to take this $50 thing apart and give it a look-see. (Boys like to tear things apart!)
There is a solenoid inside that actuates the lock. My finding was that there was some hardened goo that seeped out of the solenoid. It didn't look good! I believe this to have caused an electrical imbalance that the computer didn't like, thus sending it into error mode.
Removal and installation was a snap. First I took the top off. Then to make room for my arm to get to the door-lock, I pushed the drum all the way back and held it in place by wedging a shoe in the front end. Then I pushed the drum to the side, opposite the door-lock, and wedged it with another shoe. This gave me plenty of room to reach the door-lock. Unplug the three connectors and remove the three screws from the front side of the door-lock. (Inside door at 2:00.)
Reverse order for the install!
Thanks again for your posts which led me in the right direction!
Jun 02, 2010 | Whirlpool GHW9400SU Front Load Stacked...
I have the F11 and dL code. There is water and
Hi
Error F11 means Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Error code dl is a Door Lock Error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error. You need to check:
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Jul 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Dl codes and f11
    dL= Door Lock Error
    -Door Lock Mechanism broken or removed from the Door
    -Check Door Lock/Switch Assembly
    -Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
    -Door Lock/Switch Assembly Failure
    F11=Serial Communication Error
    Communication between the Central Control Unit (CCU) and the
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    Feb 07, 2009 | Kenmore Elite 45986 Front Load Washer
    Fdl code message
    >"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
    Door lid is not closed completely due to interference.
    Wash media buildup is preventing the lock bolt from extending.
    Machine/motor control detects open door lid switch when attempting to lock.
    Machine/motor control cannot determine if door lock is in a locked state.
    Check for lock interference with lid or lock bezel
    Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    I am getting an DL F code on my front loader
    Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
    I have a Kenmore Elite Quiet Pak 4 front load washer. I keep getting the DL and F11 error. The door is locked and won't open and the cycle will not continue. I can hear a small clicking noise in the...
    f11 eror is a serial coommunication error check the harness wirinbg tio the motor and cpu unit
    check the drive system for worn part
    check mcu motor the dl error fial code is for door lock error it will try to lock 6 times before error code is displayed that is the issue see repair clinic.com for help hope that helps
    Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
    How do i find what an error code means?
    if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
    Sep 02, 2008 | Washing Machines
    Washer will not start gives code dl&f
    Power off the wall, check to see if the connections to the door lock are tight. Or
    Try some WD40 on the door mechanism of machine (not door) & open shut a few times; with the mains off the wall.
    May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    F DL Error Code
    If you were already experiencing the F11 error code and now experiencing the Fdl error, this more than likely is a failure of the Main Control Board. F11 is a serial communications error associated with the Main Control Board, while the Fdl error is either a failed Main Control Board and/or door latch. You can replace the door latch first to see if the error goes away, but I would almost bet you have a control board problem since you were already experiencing an intermittent error code associated to it. Let me know if you have any further questions.
    Sep 16, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    208 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
