Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Wont open i set up a password for about 50% of my 2gb serial port memory and now it wont open
  • 1 more comment
  • Anonymous Dec 23, 2007
    as him
  • Anonymous Dec 26, 2007
    Same problem, set up more than half as password protected and am only able to open the non-password part (and i know the password but can't get access to the login itself).
  • Kok Seng Jan 01, 2008
    Good Day.
    Having probnlem with folloing message from a 1 GB Verbatim Store and Go USB Thumb Drive after storing data about 2 days ago:
    VSafeMini.exe has encountered a problem and needs to close. We are sorry for the inconvenience."
    The file version is 1.0.0.0
    Please advise.
    Thank you.
    Kok Seng
    kokseng_friends@yahoo.com
My friend encounter this problem too but her thumb drive is 3mb(not too sure how old). version was 1.0.0.2
any idea how to solve it? i'm trying to research on main web and other. it doesn't resolve.
The file version is 1.0.0.2
Posted on Aug 05, 2010
Yo,
if you still having this problem go to
http://www.verbatim.com.sg/products.cfm?ID=62907&driverID=1002
download vsafemini newest version and start it directly from your dektop.
Then you can reopen your files again.
this issue can happen, when the vsafemini.exe file is blocked by an antivirus program
Good Luck
tha_sida
Posted on Jan 14, 2008
Yo,
Good Luck
tha_sida
I cannot connect using serial console port (no signal / data out of serial console port). I don't have IP address of the DS4100B. I don't have its password... How can I reset it to factory default?
I am assuming you will still need console connection to do a password recovery.. however, here is the link to one password recovery doc that may help.
May 10, 2016 | EMC DS-4100B 32 Port 4Gb SAN Switch
Blackberry playpad asks for password it does not open using password and wont go into scroling
Have you tried a soft reset? (Turning the unit off for at least 10 minutes and then on again) Is the password asked for right after you turn it on? Can you get to your settings? If you can get to your settings, go to Security. Choose Development Mode and choose Disable. It will probably ask for your password. Good Luck!
Jammers
Feb 15, 2015 | RIM Blackberry Playbook with 64GB Internal...
Why do i get an error window when i press read on the program for the radio????
If the interface cable has a serial port connector, and you need to use a USB --> Serial Port adapter to connect to your computer; it may be the source of the problem. The cheaper USB --> Serial adapters have issues with timings that the serial port protocols rely on. You may have luck by reducing the speed of the serial port to something like 19200, 14400, 9600, 4800 or even as low as 2400 baud. Make sure that the adapter name (COM1, AUX1, COM2, AUX2 , etc.) is the SAME one you're telling the program to use to access the radio's memory and the port's parity, number of stop bits and error checking type match the program.
Additionally, different radio manufacturers use different methods to set the radio's memory up to be read and / or written. Make sure the radio is ready to be read and the program is trying to read - not write (and vice versa).
If you're still having issues, please reply and provide the radio brand and model, interface cables and adapters, and program software and computer Operating System.
Jan 21, 2012 | Radio Communications
GET MOBOLE SERIAL NUMBER SAMSUNG SGH-M200 AND IEMI NUMBER 358046021210241
i can't open my memory card.i have forgot my memory card password.my phone name 7610 supernova
Mar 27, 2010 | Samsung Cell Phones
I need to connect cisco 2800 router to my pc through hyperlink
I think you mean hyperterminal? you need a cisco serial cable (blue) and a serial port on your PC, maybe a USB to serial adapter if there isn't one. Set hyperterminal to use the COM port you have plugged in to, speed 9600 8 bit no parity. (8N1).
Without the serial cable you need to know the router IP and password.
Oct 31, 2009 | Cisco (UBR904) Router
Customiser 2000 will not connect to a laptop as it has a 9 pin serial port (female) and the laptops have a 15 pin (female) I have bought 2 different cables but none work it just says serial port did not...
Are you using a USB-to-serial adapter?
I *think* what the problem might be is that the COM port's not been set in Customizer. Within either of the Easy/Customizer apps, go to ScanCard>Communication Settings ... you'll open up a dialog box within which you can set which COM port your cable's going to use.
If you're compie savvy, you can go to the Windows Start button on Task bar>Control Panel>System>Device Manager>COM ports and SEE which COM port your cable's using.
But until your software knows what COM port your cable's using it will NOT recognize that you have one installed.
Please let me know if this doesn't help! Or if there's anything I can help with!! :)
Aug 01, 2009 | Janome Memory Craft 9000 Computerized...
My older hi-pro box will not work with my serial to USB adapter. It keeps saying it cannot find it on com 1,2,3,4. In the device settings it says the hipro is on port 2 and the serial/USB bridge is on port...
I just set up a serial Hi-Pro box for one of my customers on their new laptop. According to Beltone, the only usb adapter that will work with the Hi-Pro (or at least the only one they have gotten to work) is a Belkin F5U409. I know some usb serial adapters don't use true serial communications if that makes any sense, so there isn't really a baud rate. They kind of just send out the communication in bursts...
In any case, ive only tried with the belkin adapter and that worked fine with no problems. The other point here is that your Hi-Pro and Adapter are on different com ports... This is odd, the hi-pro should be on the serial adpater's com port. Also the software i was using - Noah, with a beltone module for programming hearing aids.. only looked on com ports 1-3. The computer put the serial adapter on com 8 - which would not do. I checked for available com ports and saw that 2 was unused. I set the adapter to 2 and was able to set up the program normally.
I did this on Windows 7 Professional 32 Bit. The procedure for selecting the com port is the same on earlier versions of windows.
First, open device manager, open the list titled "Ports (COM and LPT)". You should see your serial adapter in there. Double click it. In the window that opens click the "ports" tab, and hit the button labeled "Advanced" In the window that opens there will be a drop down list to select a com port. Select the desired com port and hit ok. That should fix it.
Jul 12, 2009 | Uniden Unipro PC100
I am not able to use the password for the memory card in nokia3110classic , evern after the password was set
The Password Feature is for the purpose that if your memory card is inserted in any other phone than the Phone the password was set on. The user wont b able to browse the contents. Also the memory card wont b detected on any comp..... But it will work the normal way on the mother Phone ...
Oct 12, 2008 | Nokia 3110 Cellular Phone
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
548 people viewed this question
Top Verbatim Computers & Internet Experts
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
