Question about Maytag Refrigerators
New fridge is making sound like hammer drill in concrete on freezer side in the middle. for approx. 15-20 minutes almost every hour
  • 65 Answers
The evaporator fan is hitting the housing or shroud. There is no other moving part in a freezer.
Posted on Sep 11, 2009
My hiltite 805 is not breaking wot wrong please
could be many things:
-point not sharp enough
-concrete too strong for light hammer drill
-trying to hammer too far from edge of concrete
-hammer action setting no turned on
Mar 28, 2015 | Hilti Drills
Squeaky, chirping sound & exterior of fridge on veritical middle panel and freezer side are hot
I think you should try the following:
1. turn off the power.
2. clean/vacuum the lint under and behind the fridge.
3. after a few hours, power on.
If this does not work, you will have to call a repairer unless it is under warranty.
good luck
Mar 15, 2014 | LG LSC26905TT Side by Side Refrigerator
We had a new Samsung RS267TDWP side-by-side frig delivered earlier today. The refrigerator side is cooling off nicely, the freezer side is not. Should we expect the freezer sideto begin cooling when the...
It takes approx. 24 hours for a freezer to reach optimal temperature and to stabilize, only because in a 24 hour period the machine will shut off about three times for it's defrost cycle, but like you listed, freezing temperature will be reached in about 6 hours.
Aug 29, 2012 | Refrigerators
Heard loud banging noise coming from fridge. Sound was like someone jack hammering concrete. Turned it off for a few hours. Then turned back on. Freezer is working fridge area is not cold.
The sound you heard was probably the evaporator fan hitting ice, meaning your evaporator was frozen up. It sounds like the unit is trying to cool the refrigerator but the air isn't getting to the refrigerator area because either the baffle is blocked or it's getting clogged with food or something. Find out why the cold air isn't getting to the refrigerator and you shouldn't have a problem with a frozen evaporator anymore.
Mar 26, 2010 | Refrigerators
When I was done using the hammer drill to drilling
open your chuck as far as it will go look down inside the chuck and you should see where it has come from ,if that is where it came from it will be right hand thread probably allen key or very small socket
Aug 14, 2009 | Milwaukee 0824-24 V18 1/2" Hammer Drill...
3 yr old kitchenaid side by side freezer is cold but fridge is only half cold Yhere was some ice buildup in the middle vent so I unplugged for about 5 hours then plugged back in and the next day same...
Sounds like the defrost timer is not working. There is an approx. 1/2 inch white round shaft with a hole in the middle somewhere either inside the refr. section or on the front bottom frame. If you stick a screwdriver in it and turn it clockwise until it clicks, the compressor will shut off and go into defrost. If it doesn't come on after about an hour, then turn it until it starts. Mark it to see if it turns. It should do one rotation either every day or twice a day. If it's not turning you need a new timer. Cheap and easy.
Aug 02, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Refrigerators Logo
100 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
