Question about Porter Cable Cable 0330 Speed - Bloc Finishing Sander
I have a Porter Cable finishing sander ( the kind that takes quarter sheets of sand paper) and it is chattering. I posted earlier and received a helpful answer (thank you) but I mistakingly stated the type of sander I own. What can I do to stop it from chattering? I'm thinking it is something of a mechanical nature.
  • lwatts836 Sep 11, 2009
    I was using 150 grit so that must not be it. But thank you.
    Sergeant:
  • 384 Answers
Try a less course paper (ie # 80, or #100)
Posted on Sep 11, 2009
DW411 Can I put a velcro pad on this sander so I don't have to fumble around trying to get sand paper on it
Dewalt is not going to make an accessory for you to do so, since that sander was designed to use 1/4 sheet sandpaper, and therefore takes standard paper clamped in place. You could make your own base for the sander out of thin plywood or some other suitable material, covered perhaps with a laminate or rubber surface, that would accept PSA (pressure sensitive adhesive) sandpaper, which you can buy in rolls appropriately sized for your sander. Or you can try some kind of after-market conversion kit such as this one (See also here, etc.)
If you really want a hook and loop base on your sander, I recommend you bite the bullet and simply purchase a random orbital sander with a H&L pad. Then you'll of course have to buy the perforated paper discs to go with it....
But you'll easily be able to change grits, and the performance and quality of your sanding will improve.
You might check the reviews in various woodworking magazines before you make a purchase, just so you know what you're likely to get for your money. There's a vast array of machines made, and the quality varies accordingly, and depends to some extent on your budget and intended use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 20, 2010 | Dewalt DW411 quarter - sheet palm grip...
Frozen barring at the shaft / pad union, is it worth repairing
yes it is usually bearings cost less than 10.00, you can download a breakdown from Dewaltservicenet.com to see what is involved.
Nov 28, 2010 | Porter Cable Cable 340K 14'' Sheet Palm...
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Extreme Vibration in my Porter Cable (Rockwell) 330 Sander
I also have had this problem and I found that if I hold the unit tightly and squeeze the plastic housing the RPM's will stabilize as the unit warms up. Best fix is to replace the rubber isolators that prevent vibrations from the motor from reaching the plastic housing. The isolators have become hard through age or very cold temperatures.
I read somewhere that keeping the sander stored in a warm room can also help because when the rubber is very cold it becomes hard.
Oct 07, 2009 | Porter Cable Porter-Cable Speed-Bloc...
How do you replace bearings on a porter cable 505 sander?
First I would go to Dewaltservicenet.com and in the middle of the site towards the bottom type in your model number. I found breakdown on page 8 unless it comes up faster. You will need a bearing puller or something similar because they are pressed on. It is really not that hard with the proper tools. Let me know and if I have answered your question would you please rate this response accordingly and Thank you.
Sep 08, 2009 | Porter Cable Porter-Cable Half-Sheet...
The sander is chatterin g on the oak wood and only barely stops if I apply a whole lot of pressure. I don't want sanding marks so how can I fix it?
You may be applying too much pressure. Also it is my experience with this type sander that one has to use the side of the pad. If you try to use the whole flat pad they chatter. For flat sanding I use a "Jitterbug" type sander. What you have is for coarser work I SUSPECT than what you are trying to do. The quarter sheet type would probably be better for you.
Sep 05, 2009 | Porter Cable 7336 6 Inch Variable Speed...
Replacing sand paper
Look on the side of the tool between the guide and drive wheels for a lever
Loosening or disengaging this lever will take the tension off of the belt so that it can be removed
If there is no lever, there will be a tension know on the front of the tool that you can loosen to remove the belt
Jul 05, 2009 | Porter Cable Tools & Hardware - Others
How do i refill a finishing sander
Without any more detail about your particular finishing sander, I do not know whether this will help, AND I am no expert, but here goes ...
I inherited a Black and Decker 1/3 sheet sander, with no manual, from my late brother. It is not their newest model -- from the yellow plastic and the general looks and wear, I would say it is from the 1980s or 90s. The sand paper is held by a sort of spring clamp at both the front and back. There is a slot -- perhaps half an inch wide and a quarter inch tall -- in both of these spring clamps. I inserted a wide-bladed screwdriver into the slot, and pryed away from the sanding pad to open the clamp and insert the new 1/3 sheet.
Hope this helps!
Nov 17, 2007 | Black & Decker Compact Power Screwdriver
Porter Cable Cable 0330 Speed - Bloc Finishing Sander Logo
107 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
