Question about Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook
I took out the RAM card to see what kind it was and after I put it back in, the computer won't come back on. HELP>>>>
  • 59 Answers
Remove the battery
Remove the ram again
Insert memory under proper angle carefully deep in the slot, push dowh till memory locks on both sides.
Put battery back Try to work
Posted on Sep 12, 2009
  • 60 Answers
Take it back out and make sure you got it the right way around there are gooves in the middle of the card to ensure it goes the right way round. You have to press firmly down until it clicks into place (not to hard) Make usre you have unpluged your computer when you are doing this and touch somewhere on the metal part of the case to ground you before touching it. IF that doesn't work then you may have to take it to a technichian at your local Staples or soemthing most are good at checking it out for you.
Cheers
Al
Posted on Sep 11, 2009
  • Toshiba Master
  • 13,433 Answers
I hope you had unplugged the computer and removed the battery as well.
Remove them, and take out the ram from the computer, make sure they are clean, do not use water, or clean them, you can use the eraser end of a pencil to clean the contacts on the memory modules.
Place them back in and make sure they are in the right away, only handle them from the sides.
If the problem still remains, unplug and remove battery again, (might aswell keep the battery removed untill the issue is solved.)
Remove both ram modules from the laptop.
Start up the laptop with no ram at all, it may beep or complain, or it may do noting, unplug after 1 minute.
Plug in the other memory card, plug the machine to power, try starting up, if it works, turn it off and place in the other aswell, turn on and see if the machine works, if it does, problem solved. If it does not work.
Remove both ram modules, try the other memory on both slots and try starting up each time, remember to unplug power every time.
If the problem remains then do the same with the other memory module try it on both slots.
If the machine still doesn't work something is wrong, possibly you worked inside the laptop while it had power or it was plugged in or the memory was damaged by static electricty, very uncommon, but I don't see any other reason at this point.
Take it to a local professional for a checkup if the issue still remains.
  • Toshiba Master
  • 4,806 Answers
Remove the battery and AC power, take the RAM back out of the slot, clean the brass pins on the RAM and any dust that maybe on the slots.
Re-seat the RAM in the original slot you took it from making sure that the RAM clips into place properly.
Regards.
    President:
  • 1,653 Answers
Take the RAM card out altogether and boot the machine to see if it is OK. You should get a RAM error. If it does start to boot then jump into BIOS setup and check everything. Then turn off the book and reinsert the RAM and make sure it clicks into place correctly. Turn on the machine again and it should alls be OK. If not then its repair shop time.
Installed upgraded RAM in my HP Pavilion a1030n. Now computer will not power on even with the old memory put back in. what's wrong? Everything was fine until I unplugged the computer. I took off the...
YES. The slots are for different kinds of memory. ONLY use the 2 new cards and insert them into the SAME colour slots. You should NOT mix memory types. Forget the old modules.
Feb 14, 2011 | HP Pavilion a1030n (PS585AA) PC Desktop
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
I have Display problem in vt 8233a motherboard
Problem often occurs on a computer display, usually the problem as a hardware malfunction.
way to identifying it is to perform tests on computer hardware (troubleshooting)
> Sweep ram slot with a small brush or small paint brush is not used (new)
> After cleaning the ram slot, use the eraser to clean the copper surface on the ram you are.
> When you're done, plug the ram in the slot. (If you have a new ram to do the troubleshooting is better)
> Reattach the power source on your computer and then switch on your computer.
> Still not working?
> If you use the display card, remove the display card and do the same as you did on your ram and ram slots.
(If you're not using the display card, the better you get the display card to make the process of troubleshooting)
>Turn on your computer.
(If your computer is still experiencing the same problem though has to do the troubleshooting on the display card)
> Get at / ATX new power supply to do troubleshooting, (damage to the power supply will also cause the computer not display
If the computer still can not function normally means that you have the problem still appears,This requires you to perform more detailed troubleshooting process.
Firstly, you need to provide a motherboard and processor is still working (new) to do this process.If you already have all the equipment, you can start to make the process of troubleshooting your hardware one by one.I believe there is enough equipment for you to perform troubleshooting, problem you will be able to identify you and you will be able to solve by itself.
Hope this can help solve your problem.
thank you
Jul 21, 2010 | DFI P4M266/VT8233A (MBDF-PM10EL)...
My parents have a Dell Dimension B110 computer and they were going to install some new RAM. They took the old ram out, realized they bought the wrong kind, put the old ram back in and now the computer...
Make sure the ram is installed correctly. You didnt break it when you put it back in did you ...
If you get it going again... please go to www.4allmenmory.com and have them scan your computer. Review their results and recommendations
Im sorry their computer isnt working.
Thanks for using fixya.com
a
Oct 26, 2009 | Computers & Internet
HP Pavilion desktop. Installed new RAM, won't power up.
the power supply seems to be fine> but we can check by removing the BIG ATX white connector on the motherboard> if the light is still on then the power supply is fine>>> then
we can first remove all the RAM from the motherboard> then connect the computer to power and then see if the Computer beeps or not> if it does the motherboard is fine > if it doesnt then the motherboard need to be replaced
Oct 17, 2009 | HP Computers & Internet
No Signal To my Monitor and no beep.
First refix the RAM and Pci graphic card.
Pull cmos cell from mother bord for 15 minutes then put again into its position then all settings are defaults.
Then if still face problem then check with other RAM.
Aug 13, 2009 | Computers & Internet
Toshiba satellite a65-s126. need to add ram. how to replace the memory module. please help. it is so very slow.
If your laptop is slow then it is not necessary for you to increase you system RAM. Try the following steps Kindly comment if these steps do not work. I shall lwt you know how to install another RAM module.
1) Open internet explorer -> Tools-> Internet options ->General -> Browsing History -> Delete -> Check all boxes -> Delete. (IE 8, The process is quite similar in other browsers as well)
2)For XP
Start-> Run-> type temp-> Ok-> Select all-> (Shift +Delete)
For vista
Start-> Start Search-> type temp-> Ok-> Select all-> (Shift +Delete)
3) For XP
Start-> Run -> type %temp%-> Ok-> Select all -> (shift+delete)
For Vista
Start-> Start Search-> type %temp%-> Ok-> Select all-> (Shift +Delete)
4) Turn off laptop, Remove battery , Remove AC adapter, Press power button for 2 minutes. Put both back on. Turn on laptop.
5) Run virus scan and check for malware and other virus related issues. If anything is found delete the infected files.
6)
For XP
Go to Control Panel-> Add and remove programs-> Remove all unnecessary softwares
For Vista
Go to Control Panel-> programs-> Installed Progams->Remove all unnecessary softwares
7)
For XP
Run-> msconfig-> Startup->Disable all
For Vista
Start search -> msconfig -> Startup -> Disable all
8)
Check for the system RAM. If your laptop has 2 memory cards installed. One might have failed. So try to remove it and fix it back again and check.
Jul 31, 2009 | Toshiba Computers & Internet
Upgraded RAM, added USB port card at rear panel ... now no worko
Try reseating the RAM. If the computer won't even post it's probably a RAM problem. I worked on a machine about a year ago that took almost two days to get the RAM to seat properly. It was doing the same thing worked when it wanted to. I finally used the end of my BIC lighter to beat it in. You can try to reinstall the old RAM to see if the RAM is the problem or try installing it one stick at a time.
Jun 27, 2009 | Acer Aspire T310 PC Desktop
Windows xp sp3 maximum amount of memory
HI,
Of course it can be done, your computer can take up to 2BG of ram (memory) and the slots are located inside the computer tower like this >>>>>
Your motherboard will have 2 slots like in the picture and will take 2 x 1BG (1GB in each slot), just make sure you buy the correct speed and type memory so it's a good idea to take your memory with you when you buy is so there is no mistakes.
Good luck
Jun 19, 2009 | E-Machines eMachines Desktop PC
Put new vid card in pc it will boot but no pic put another vid card in it boots just fine
What kind of fan do you have installed? Cpu wise? it sounds like your cpu is overheating when your playing games. Due to high graphics. Try getting a better cooling system to stop the shutdowns.
With the ram, is it because your Gpu shares some of the ram?
This is common with chipsets and some GPUs.
Sorry or posting twice, im having some issues of my own here ;)
Sep 08, 2008 | ASUS P5N-E SLI Motherboard
Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
