Cfm Daikin R410a Split System Air Conditioner
Problem for Cfm Daikin R410a Split System Air Conditioner
Fan Coil Unit is Cycling on and off. But the room is still hot.
By zephed20 on Sep 11, 2009
Indoor fan coil unit.
Outdoor chiller.
Rooms set point is 72 degrees.
Took a reading of 83.
Fan will not come on.
When it does come on, cold air does blow.
Belts are fine.
Drain pan is not clogged in any way.
Cleaned the condenser.
WHAT IS GOING ON?!
Solution #1
posted on Sep 12, 2009
Not Rated)
papps54
Rank: Wiz
Rating: 95%, 12 votes
Check electrical connection at the T'stat and the indoor blower . Sounds like a loose connection.
Comments:
Sep 12, 2009
- Check electrical connection at the T'stat and the indoor blower . Sounds like a loose connection.
Was this helpful?
Yes
No
Popular Solutions for Cfm Daikin R410a Split System
Questions and Unsolved Problems for Cfm Daikin R410a Split System
Do you recommend Cfm Daikin R410a Split System Air Conditioner?
Answer
Answer
hi, i have 2 daikin air conditioning unit, 1 is working perfectly but when the 2nd is turned on the... (More)
Answer
theres a weird odour coming from my system, it doesnt matter if its on cool or heat, any ideas? Its... (More)
Answer
Daikin unit displaying a message of Unit 0, the eye symbol and E3 The model is Daikin BRC1D61. The... (More)
Answer
Daikin aircon just blinks green light and wont do anything, but will start working randomly if left... (More)
Answer
why does my daikin single split fan coil stop completely for about 30 sec and run again throughout... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cfm Daikin R410a Split System...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
