Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Drain hole in top fridge section flooding and icing up under vegtable storage draws.
Despite being clear water is not draining down the hole at the bottom back of the fridge section. It is flooding over on to the bottom of the fridge compartment and freezing.
  • pataoife Jan 10, 2009
    Drain hole doesnt seem to allow water to escape. I defrosted the freezer compartment, but after a few weeks the problem has resumed.
  • English9 Feb 15, 2009
    I've got this same problem, i will try to tilting the unit back and see if that helps.
    Problem Solver:
  • 17 Answers
Maybe you fridge is tilting to far forward some times a fridge needs to lean back slightly only by 5 degs so adjust the foot t the front. this will mke the water flow towards the back and also help keep the doors sealed better
Posted on Dec 10, 2007
Whirlpool refrigerator ER2CHMXPL00 & leak
If you have water leaking into the fresh food section of the refrigerator, then the condensate drain if either frozen at the evaporator OR clogged at the drain pan or both. There are air vents in the top of the fresh food section to allow cold air down from the evaporator compartment and return air up from the fresh food section, and these holes cannot be covered or closed off. Check the drain trough under the evaporator for ice build up. Also check that there is nothing stopping the water flow down at the drain pan. If there is no water in the pan under the refrigerator down by the compressor, you have a restriction that needs to be cleared.
Jun 25, 2016 | Whirlpool Refrigerators
Hi there water building up and flooding back from my fridge drain hole.hotpoint model number rfa07
clean ice from drain hole then take a wire hanger and cut it to about 3-4 inches , wrap one end around defrost element anf the other end down the drain hole . use a turkey baster to force VERY hot water down drain hole to clear build up and debris
Feb 24, 2013 | Hotpoint RFA60 Bottom Freezer Refrigerator
Whirlpool top freezer refrigerator has water in bottom refrigerator
when the machine goes into defrost the heater in the freezer comes on and melts all frost off of the evaporator coil,the water goes down a drain line down to where the compressor and condensor coil is and there the water evaporates,your drain is blocked so the water can't drain down and leaks into the fridge section.when you write looking for answers you have to send the model number off of the machine,if the freezer is on top open the fridge door and look on the left side wall up near the ceiling and there should be a tag with model number,unplug the fridge or shut down the cold control,remove everything from the freezer and remove the back inside wall of the freezer,with a hair dryer melt out all the ice under the evap coil,i use a steamer to clean out the drain,if you don't have one you can try a turkey baster or anything that will push air or water down the drain hole,when you think the drain is clear pour hot water into the hole,if it drains down then it's clear,if not keep hitting it,you can also heat up the back center wall and ceiling in the fridge section to help melt out the ice.there's also a heater probe you can buy that you stick into the drain and it raps around the heater,when the heater comes on the probe heats up and keeps the drain from freezing up,you can also use a ground wire from an electrical piece of house wire or from a cable wire,cut a piece around 6 inches,stick it into the hole and rap the end around the heater,if it's a glass heater connect the wire to the metal in front of the heater,if 6 inches is to long trim it down a little so it fits.good luck,if you need anymore help let me know.
Jun 19, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is collecting on the top shelf & in the bottom of the refrigerator. Water is clear. Water at bottom will partially freeze. Cleaned the coils & made sure all vents were unblocked. Problem...
if you have water leaking down from the freezer into the fridge you have a blocked drain in the freezer,if you pulled off the back inside wall of the freezer and melted the ice off of the coil you should have noticed that the water wasn't draining down the drain hole under the coil.pull off the back inside wall of the freezer,look under the coil and you'll see a drain hole,when the freezer defrosts the ice melts and goes into the drain hole and down into the pan at the bottom of the fridge where the compressor is and it evaporates,your drain is blocked and the water is draining into the fridge section.unplug it,melt out any ice with a hair dryer,now you have to clear the drain line,i use a steemer to do this,it blows steem down into the drain and cleans it out in no time but if you don't have a steemer you need something that will push air down into the hole like a turkey baster or even a shop vac,pull off the hose and stick it into the other hole and then you can blow through the drain line with it,when you think the line is clear pour hot water into the hole,if it drains through your done,if not keep hitting it,also if you open the fridge door and with the hair dryer heat up the middle ceiling in the back,that's also part of the drain,in the middle of the ceiling and back wall where they meet,heat it up for around 5 minutes and then try the water,it will clear out,it could take around an hour or so to do it.
Jul 08, 2011 | Kenmore Top Freezer Refrigerator
Water is leaking into the refrigerator from the freezer it seems to be worse when the ice maker is on
if it's worse with the ice maker on i'd have to say the ice maker is leaking but normally the water is from a blocked drain in the freezer.unplug it,remove everything out of the freezer,pull off the inside back wall of the freezer,melt out all the ice with a hair dryer,next you'll see a hole under the evap coil,that's the drain,you have to free it up,i use a steemer to blow down through the drain but if you don't have a steemer keep heating up the area where the drain hole is,you can try using a turkey baster to blow through the drain,when you think the drain is clear pour hot water into the drain hole,if it goes down you're done,if it doesn't keep heating it until the water drains down the hole.also open the fridge door,in the top of the fridge in the middle of the ceiling and where it touches the back wall you'll see a mold,that's also the drain,heat that area up with the hair dryer to melt out the ice in the drain.the problem is slime builds up in the drain,when the fridge goes into defrost the heater comes on and melts the ice off of the evap coil and the water goes down the drain and into the drip pan on the bottom of the fridge,your drain is blocked and the water is leaking into the fridge,the drain has to be cleared.good luck with your machine.if i can help you with anything else let me know.
May 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I don't know the name of the part, but there is a daily leak coming from inside the refrigerator about the top shelf near the back. We placed a bowl there to collect the water
most likely the drain hole is clogged. So everytime the fridge goes on defrost, thetes no whete for the water to drains so it drains down into the refrigerated section. Remove back panel in freezer. Drain hole is located under the evaporator. therte should be a thin metal pan under evap and drain hole is in the middle of pan. Remove ice and clear drain hole. Pour hot water down it and listen to make sure its flowing into drain pan under rrefrigerator.
Mar 04, 2011 | Kenmore Refrigerators
Hi, I have a 20.9 cf (#ET1CHK/ET1CHM). Water
Dec 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Magic chef fridge #ctb1722grq
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Oct 20, 2007 | Frigidaire FRT17G4B Top Freezer...
Ice in Refrigerator Section
there are 2 possibilities. first the drain is blocked causing water to overflow from the defrost water gulley at the bottom rear of the inside of the fridge. this can form ice as it is close to the division between fridge and freezer. second, the .fault of ice growth can be caused by breakdown of the cabinet insulation. of the two, the first is the moree likely. to test drain is cloear, pour a little water down the drain. if it does'nt flow freely, push something flexible down the drain hole till blockage is clear
Apr 14, 2007 | Sub-Zero 650 / O Bottom Freezer...
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
1,109 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
