Alarm sounds and F dL flashes on w/p front loading washer
    President:
  • 1,776 Answers
Fdl is a code that indicates a door lock error. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Posted on Sep 11, 2009
Ocassinally my washer machine won't start, it Makes a sound of an alarm showing DL and then F. I shut it down and I quick it at the entrance of water area and then she starts. What should I change?
'DL' + 'F' stands for Door Lock Fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Please score this solution accordingly. Thanks!
Apr 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer displays error f did what the manual says but still same problem
it shows f11,also DL,
I did change the door lock,
same alarms.
it's fine for few wash but when it happens again it just stop and show
F11.
Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When I hold the button for it to start it clicks and starts flashing F then dL It will not start washing
The "f" part is saying that you have a fault, and the "dL" part indicates that your control panel thinks that there is an issue with your door lock. The brain will attempt to lock the door six times, then flash the error code. Press pause/cancel twice to clear the alarm. Then check your lock. Usually, it's something loose on the lock or catch; it can be the wiring to the lock being loose, or the control panel may have a fault. Start with the lock, and work back to the control panel.
Best regards, --W/D--
Aug 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer beeps and flases f dl
it probably flashes also f11....to correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Washer flashing dl on the screen
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Try everything else, like reseating the connectors, then look here:
http://adsisecurity.com/KenmoreWasher.htm
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
