Question about Brother MFC-5840CN All-In-One InkJet Printer
I have a problem with the black ink color because its missing in the printout this is aMFC5460 printer
Smudge and missing ink
remove all image units. clean the class where the laser writes on the drum with machine no laser. so clean. smudge what color replace the that color image unit.
Apr 07, 2014 | Konica Minolta Magicolor 1600W Printer
Tip
Black and color inks are not printing
For inks which are not giving color and black printouts during printing<br /><br /><br />1. Power Cycle the printer<br />2. Check ink levels<br />3. Clean Cartridge contacts and nozzles<br />4. Align the printer<br />5. Reset the printer<br /><br />Consider the following<br /><br />Paper or Media compatibility with the printer<br />Check if printer is working fine as standalone<br />Check ink cartridge if genuine,refilled or fake<br /><br />Lastly contact vendor to check if it is replaceable since the printer is still in warranty<br /><br />Hope I help you a bit.<br /><br /><br /><br />Your's Truly,<br /><br />Christian from HP<br />
on Mar 27, 2011 | Office Equipment & Supplies
Can it (HP deskjet F380 all in one) still print with only color cartridge or only black cartridge ? Or Should two cartridges remain together to print even one is empty ? Thanks
the answer to your question is yes,it can still print with only one cartridge installed.
If you do not have a replacement cartridge, and the quality of your printouts is not a concern, you can still print in ink-backup mode. Consider the following guidelines before printing in ink-backup mode:
  • If you remove the tri-color cartridge, printouts will be in grayscale.
  • If you remove the black or photo cartridge, the product will print more slowly and the colors in the printouts will vary.
    press OK button to clear the error message like cartridge missing after removing one cartridge.
Jun 20, 2011 | HP DeskJet F380 All-In-One Printer
I bought some cheap toner and noticed almost immediately streaking and missing lines. I replaced it with HP toner but now black won't print at all.
If your printouts are streaked or faded, missing black or other colors, have blurred or fuzzy text, or ink streaks or smears, or show other problems, please refer to the link below for troubleshooting steps for print quality issues.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01957673&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Apr 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
What is wrong if the colour black, when printed, looks like red?
Hello Dan, hi!, it looks like your printer is either using red as black, it does this when a color is missing, in this case the black ink, the routine is when a color is missing, the printer reproduce that missing color from what ever color is available, so your printout is a near very close imperfect copy. I suggest you clean your printer ink cartridge and cradle for crystallize dried ink. use warn water as a dissolving agent, a damp of warm water on those dried ink will loosen it. Use swab such as ear-buds, to loosen it.
May 28, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Nov 28, 2009 | HP Office Equipment & Supplies
Epson CX4600 printer - will not print color at all
no it should work at it is. if you installed the plug and play printer driver. have you removed the protection tape from the inc tubes?
Oct 12, 2009 | Epson Stylus CX4600 All-In-One InkJet...
My printer is not printing. it will run the paper
I see you don't have much knowledge about printers. It always helps to know something about your printer. It seem you have a color printer. Usually a color printer has two cartridges. Black cartridge and color cartridge. The color cartridge usually contains three colors; cyan, yellow and magenta. If the black cartridge is empty, you won't see black text in the printed paper. Print a small photo and see. If it has all the colors, but looks dull (without proper black color), that means only the black cartridge is empty. If it is greenish, the magenta ink is missing. Generally orange colored printouts suggest cyan is missing. Likewise, purple color means the yellow ink is missing. If you installed the printer properly using the CD from the printer manufacturer, you will be notified when the cartridge is empty or close to run out of ink. But if Windows automatically installed your printer, then the system won't give such information. From the information you have supplied, I believe your blck cartridge is empty or missing. Oh, I almost forgot to say, some manufactures sell some printers (for example some Canon Pixma models) with only the color cartridge. Switch on the printer and open the printer cover. The cartridges will move to the middle. You can check whether the black cartridge is missing. Do not hesitate to contact us for further help.
Aug 13, 2009 | HP Office Equipment & Supplies
Too much green
Printing too green is a sign of low or no Magenta ink. Might pay to look there. (Green is Cyan and Yellow ink, so Magenta is missing to make Grey/Black)
Sounds like someone might have also managed to mix up an ink cartridge and put it in the wrong slot?
Check that the nozzle patterns for each colour are in the right place on the print out according to the sample in the manual / online. Maybe Magenta is missing altogether?
Apr 21, 2009 | Canon i860 InkJet Photo Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
54 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
