Question about Dishwashers
The latch seems to disconnect stopping the washer from finishing the cycle. The dishwasher is Model MDB4000AWA Serial # 15724156UB Pressing on the door seems to keep the cycle progressing. The problem is getting worse.
    Sergeant:
    Champion:
  • 205 Answers
Dear sir/mam
please change the door limit switch (door lock) after using for several times the terminals of the doorswitch will be weeken.
Posted on Sep 11, 2009
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Jul 31, 2014 | Kenmore Dishwashers
MY FRIDGIDAIRE AFFINITY KEEPS PAUSING DURING CYLES DOSENT MATTER WHAT CYCLE I CHOOSE. IT STOPS ATLEAST 5 TIMES PER CYCLE AND SOMETIME WONT FINISH THE CYCLE. MODEL NUMBER FAFW3801LW3
Hi Brooke, thank you for allowing me to assist you!
Often this happens because the washer door is not securely latch or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, try reprogramming the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. If issue persists, then more than likely the unit has a faulty door latch, a communication error with the control board, or a potential wiring failure. You may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Best regards!
Oct 30, 2013 | Frigidaire Affinity ATF7000E Front Load...
Door latch
The safety latch needs adjustment or is loose or worn out if you open the door on door side top you would be able to feel the the safety switch with your finger click on and off it should click very easy if not replace it make sure Dw is off or disconnected.good luck
Oct 14, 2013 | GE Nautilus 24" Built-in Dishwasher
Frigidaire dishwasher model # FPHD2491KF
It seems like you are experiencing a faulty door latch and control board communication. This would need to be diagnosed by a technician and the correct part(s) replaced.
Aug 29, 2012 | Frigidaire FPHD2491KF Dishwasher
Yesterday opened the door to dishwasher, and heard a thud sound. Now the door weighs a ton. I believe a spring/bracket broke, but can find no evidence of it. The dishwasher is working...
Either the door spring is broken or the linkage that ties the spring to the door hinge...the springs hook onto the leg/frame asm that supports the tub then the spring fit into that linkage and the liknage fits onto the door hinges.
This link is a parts breakdown for your model and item #6 is the spring and item #11 is the linkage..their is 2 of them (one on the left and one on the right) and its reccomended that both are replaced at the same time
Here is that link so are can get a good look of how and where they go http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dishwasher-Parts/Model-MDB4000AWA/3048/0130000/M0512217/00002?blt=06&prst=0&shdMod=MDB4000AWA
GENE
Sep 10, 2011 | Maytag 24 in. MDB4000 Built-in Dishwasher
Washer goes through cycle, until around 11 minutes until finished it stops, and goes into dL. Will not finish load. What does this mean?
Hi.
the error F/dL means Door Lock Error
The error is prompted when the door cannot be unlocked.
Here possible causes.
Door Latch mechanism broken
Door Switch Assembly defective
Wire Harness from Central Control Unit to the Door Latch or Switch Assembly broken
Central Control Unit (CCU)
Door Lock or Switch temporary failure (it can be reset disconnecting power)
You will probably need to replace the door lock assembly. Parts must be tested first.
Regards.
Ginko
Apr 28, 2011 | Kenmore HE2 Plus Front Load Washer
How do i adjust door switch on a maytag dishwasher model mdb4000awa ?
With a philips screwdriver turn the adjusting screww inside locking lever mechanisim, The latch at the top frame has adjustment screws too.
Vitally
May 14, 2009 | Maytag MDB7100AWB Dishwasher
I own a Kitchen Aid KUD102frss dishwasher. The door is not closing properly. It appears to be the latch. The start button blinks
you might have started a cycle and opened the door by mistake.  try pressing HI TEMP, AIR DRY, HI TEMP, AIR DRY close door to latch, press cancel.
it worked with mine.  you can give it a try.
Aug 20, 2008 | KitchenAid Dishwashers
Dishwasher latch problem
soundslike either the latch itself is malfinctioning or hteswitches on the mounts are going bad, either way a new latch assy 99003347(part number). comes with new latch and switches, goes for abot $40 and easily changed by removing innerdoor panel and swapping out...DISCONNECT POWER FIRST!!!
Mar 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
Owen Barnes
