No cd / DVD drives
I have been using a hard drive and registry clean up tool that has got my pc working much better but my system no longer recognises my CD / DVD drives. I have tried uninstalling and rebooting but with no success? I have also tried downloading the latest driver but when i try to install it says there is a .dll missing?
  • kevx37 Dec 12, 2007
    Thanks for response, i had thought of that but will the restore put back all the errors before i used the clean up tool? My pc was a real pig, explorer wouldn't work properly, it wouldn't shut down or start correctly and was real slow, i don't want to go back to that again. I hoped i might be able to fix it without restore?
  • Opsy Dec 31, 2007
    I can't see my DVD drive again and I have tried restoring to factory setting. Would physically removing and replacing the drive solve the problem? Please reply asa soon as possible, Thank you.
    Sergeant:
    Champion:
  • 317 Answers
You can use the System Restore to go back to when it worked, if you did not backup the registry manually, hopefully that will work.
Posted on Dec 10, 2007
  • Baja Data / Jay Arias-Chavez
    Was your problem solved? Do you have more information or questions?
    The more information you provide to us, the better we can help.
    If the solution was good, please rate it accordingly! :D
    Thanks!
    Try this:
    Use the System Restore (or undo what you did with the clean up tool) and MANUALLY go through the cleanup process and skip anything related to your drives, sometimes when you do things the hard way, really goes a longer way when dealing with the registry; remember it's like the nervous center of the brain, if you cut a neuron which you should not mess with, bad things happen, same with the registry. :D
Does not recognise when cd is inserted
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Jan 09, 2013 | Toshiba MK3259GSX 320GB SATA300 5400RPM...
Both DVD and CD not working
if there not being recognised
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jul 19, 2012 | Computers & Internet
Dvd not recognised, drive recognised
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Dvd-rw dvr td 09a ata Drive not recognised by software
if its not recognised in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Feb 10, 2012 | Pioneer Computers & Internet
Toshiba Satellite laptop no longer sees DVD drive
Goto start -> run ..... type regedit
hit ok.
goto the following registry setting
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Look to the right and delete the following
"UpperFilters" and "LowerFilters"
Close regedit and restart PC. If that doesnt work then the dvdrom is bad.
Sep 11, 2009 | Computers & Internet
Installed new HD using image from old Hard Drive. Everything works fine, except Windows XP Professional SP3 no longer recognizes the DVD Rom Drive. I tried Windows XP Fixit no luck. Computer does not...
Hi!
This can be easily fixed by delete the lower and upperfilter keys. Please follow the steps below:
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Aug 30, 2009 | Computers & Internet
Toshiba Satellite P105-s6147 CD/dvd drive some how uninstalled
Registry edits not usually a good idea. System restore is your friend. Some DVD burning apps will change your registry and cause the CD/DVD to disappear. Uninstall the new burning app, or system restore to a time you know it was working.
Jul 24, 2009 | Computers & Internet
Loosing cd/dvd completely from device manager
check your dvd in bios. is it recognised in bios ?
also try to push your dvd, dvd connection to motherboard might be loose.
Jul 31, 2008 | Acer Aspire 9300 Notebook
CD-ROM won't read discs
there is no problem with the system. only you need to clean the lens using CD/DVD cleaner.
Jan 05, 2008 | Gateway (5500778) Internal 32x CD-ROM...
Computers & Internet Logo
94 people viewed this question
Alun Cox
David Payne
David Payne
