Question about Coleman Camping, Backpacking & Hiking
Which end opens on a coleman max flashlight. I am trying to change out the batteries and I can't get it to open. Any suggestions?
3 Suggested Answers
dcramer531
  • 1654 Answers
SOURCE: How do you change the batteries on a Coleman
All The info I can find nothing tells us how to change the batteries. Is this a rechargable light, if so the batteries are not available for replacement. If not then the top has to screw off, or the bottom plate must screw off, there isn't any other way. What I have read is that these on this light are very hard to remove, at least that is what folks are complaining about. this light has also been discontinued and no longer availabe. if your afraid of breaking the light then I would contact Coleman for their advice since there seems to be none to be found on any bulletins they have put out.
Posted on Apr 28, 2011
I got it off. All you need is pliers. You take pliers and twist the bottom of torch with them. It'll come off in a minute or two, just keep twisting!
Posted on Feb 24, 2013
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
How to open Coleman battery lock flashlight
Sorry no idea with no picture . Coleman makes millions of lights . many unscrew either top bottom or both .
Oct 14, 2015 | Coleman Camping, Backpacking & Hiking
I have a coleman companion flashlight/lantern and need to disassemble it for battery replacement. i can`t fiqure out how.
Really? Put the flashlight down and slowly step away from it and if that doesn't work threaten it with a hammer?
Seriously did you read the package directions? The pointy end with the gray ring is the end most likely screws off to put the AA batteries in.
Jun 06, 2015 | Coleman Camping, Backpacking & Hiking
How do you open a Coleman flashlight
You need to specify the model of the flashlight. However, for most of them you simply unscrew the bulb head or the battery end cap, empty the old batteries and insert the new ones with the positive end of the batteries always pointing toward the bulb end and the negative end of the batteries toward the spring in the end cap.. Be sure to discard the batteries properly. Contact your local trash disposal company to determine where and how to dispose of them.
Jan 02, 2015 | Camping, Backpacking & Hiking
How do I remove the battery?
This is not intended to be a user replaceable battery, although I have found a replacement battery on-line.so that means that SOME people have replaced them. the cost is $9 +s&h. I don't think most camping outfitters would be able to help you with it, But it would be worth a try.
My suggestion would be (if you have one in your area) take it to a Batteries Plus store. They are quite good at replacing batteries that are NOT meant for user replacement.
Best of luck to you.
May 12, 2014 | Coleman Camping, Backpacking & Hiking
Does the coleman charger 1 spotlight model # 5347a718 need a battery
Yes it does.
See the product details at the following links:
http://www.amazon.co.uk/Coleman-Charger-One-Chargeable-Sportlight/dp/B0002JSZVU
http://www.coleman.com/coleman/parts/ProductImage2.asp?product_id=5347A718
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Good luck.
Apr 15, 2011 | Coleman Camping, Backpacking & Hiking
Batteries are stuck in the flashlight. How do I get them out without distroying it?
If they are stuck, they have probably leaked and the flashlight is probably corroded already. But here are two suggestions. Get a heavy piece of string and tie it securely around the flashlight at the lens end. Tape it on with duct tape for good measure. When hung by the string the lens end of the flashlight should point up and the open end should point down. Stand in a place with lots of space and no windows or pets or people around. Swing the string over your head to generate some g's. The batteries may come flying out. Another suggestion is to drill a hole in the battery, put a long screw in it and pull it out. Wear safety goggles. If the second battery is also stuck you will need a long drill and a longer screw. Good luck.
Nov 29, 2010 | MagLite Mag LiteĀ® 2x 'd' Battery ...
Camping, Backpacking & Hiking Logo
469 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
