Question about Dryers
Drier wont do anything timer use t click now dose nothing
  • anantha reddy
    anantha reddy May 11, 2010
    please check the heater connections, the motor connections,and the supply at both the points heater and motor then confirm with us.
  • 6,784 Answers
HI, this is a simple fix here. The timer mechanism has failed at this time. Simply replacing this failed module will correct this issue. The actual failure is within the timer motor itself.
Posted on Sep 11, 2009
Whirlpool drier not drying and wont shut off
Bad timer. Your timer controls when it shuts off also the heating.
Mar 23, 2015 | Whirlpool Dryers
My washer is not working it has power but it wont wash it wont rince it dose nothing
Would love to help you but I need to know if it is displaying any error code?
Feb 18, 2015 | Kenmore HE2 Plus Front Load Washer
Built in washer drier wont start
What brand and model? Turn off the washer/dryer breaker, wait 15 seconds, then turn on (reset) the breaker.
Jan 19, 2012 | Neff Washing Machines
I have a MEDC400VWG drier.Woked fine yesterday. Put clothes in it today. Pushed start button. nothing happened. Smelled somthing getting hot. opened drier. Heating coils lit up. (with door open). Turned...
Sounds as if the motor centrifugal switch is stuck. Check to see if lint built up around switch or centrifugal mechanism on motor shaft. Rap switch with the handle of a screw driver hard but don't break it .
Nov 01, 2010 | Maytag PYE3300 Dryer
My Maytag dryer model pye2300 stopped working one day randomly. I know its not a fuse issue to the 220 outlet in the house, because I tested the oulet, and the drier still is receiving electricity, because...
The timer on your dryer is more than likely bad. You already know what the timer is and where located. Not really that high priced thru ebay or an appliance repair outlet. Usually just a screwdriver and a small socket is all you need to change. Great sense of accomplishment when you finish and it works while saving a lot of $$$$. Stan
Apr 02, 2017 | Maytag PYE2300AY Electric Dryer
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
Timer wont advance, drier wont heat
Hi, the timer module mechanism has failed. the timer motor is unable to advance the mech at this time. you will need to replace the entire timer module. this will fix your issue.
Jul 17, 2009 | Whirlpool LER4634J Electric Dryer
Drier button does not work when push it to start machine
You need to check the dryer door switch. I may be bad. If the timer is clicking it is probably working fine. Also you need to check that the dryer is getting power to the unit. Check your breakers and also pull the unit out and look at the dryer cord. Check the terminals for a short or burnt looking one. Once you have established you have power going to the unit, you can find where the comunication stops within it.
Apr 09, 2009 | Kenmore Dryers
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
