Question about Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 plus
When i turn on my printer the green on light is only on for a split second then the paper and ink lights start flashing their red lights and i cant get anything printed off. it started right in the middle of printing something and ive tried turning it off, unplugging it, nothing seems to work.
    President:
  • 1,653 Answers
Make sure that the head can move on the carriage bar as this indicates a head assembly lock or jam. Make sure all the paper paths are clear and there is no tiny piece of paper stuck. Power it back on. If this does not resolve then you will need a visit to the repair shop or buy a new printer which is probably cheaper!
Posted on Sep 11, 2009
My Epson Stylus photo 830 flashing lights
Got the alternate red/green flashing light ona photo830. The app shown by Bill Miller sorted the problem and got the printer back on line. Use the 'protection counter' / 'reset counter option'
Thanks Bill :-)
Mar 03, 2012 | Epson Stylus Photo 830 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I replaced the blue catridge and now both red
If the red lights are flashing simultaneously, it means that there is something blocking the printhead from moving. check if all inks are installed properly and the ink carriage cover is closed tight. If both red lights are flashing alternately,it means that the waste ink pad is full and needs to be replaced. This part is not user replaceable so you need to take in the printer for service.
Apr 11, 2010 | Epson Stylus C88 InkJet Photo Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson C88 shows red alternately blinking lights
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Feb 05, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson C88 will not print, is flashing both paper and ink lights
I think you need to reset the counter, you can either take it into a epson service centre & have them reset it, or download a programme online.
you just need to google it, just type in service reset C88 that should do the trick.
Nov 06, 2009 | Epson Stylus C88 InkJet Photo Printer
GREEN LIGHT KEEPS FLASHING ON M
www.aa1consulting.com
sounds like it may be a driver problem or perhaps the spooler service needs to be stopped and restarted
Jul 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Both lights flashing on c88
Were you trying to feed a shirt through the printer?
LOL, press the center button.
Jul 26, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
Will it ever print again?!
mine did that. it was a full cartridge and it was still saying it was empty. tech support told me i had to reset the chip but mine was a refilled cartridge. then everything worked fine but i had the reseter
Feb 05, 2007 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
318 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
