Question about Bose Wave Radio
Alarm How do I disable the alarm once set
  • Ms Frog Mar 09, 2008
    How do I turn off Alarm 2
Push the Alarm Set and the Alarm Mode button at the same time. Alarm 2 will start to blink and then you can use the Alarm mode button to deactivate it.
Posted on Jun 16, 2009
Watch the display as you push the alarm button and as you push it the mode should cycle from "off/nothing" to "bell alarm" to "music alarm" and back to "off" for each push.
Posted on Feb 03, 2008
2 Suggested Answers
SOURCE: Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
Posted on Nov 17, 2009
I have a Timex T311 clock radio. How do I shut off alarm and radio everyday. As I no longer need to wake in the am.
On the Timex T311, to disable the radio alarm, press the Radio Alarm button once. The Radio Alarm Indicator light should go out and the radio alarm won't sound. If you press the Radio Alarm button once more, the radio alarm will toggle to on and that indicator light will come on. Similarly, press the Buzzer Alarm button once to enable the buzzer alarm and press it again to disable the alarm.
See page 9 of the manual to see the directions to toggle these alarms on and off. The manual is available from Timex Audio on the product page: https://timexaudio.com/support/product/T311/ . The direct link to the manual is https://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf .
I hope this helps.
Nov 15, 2017 | Timex Audio Players & Recorders
How do I deactivate my aps57c mobile audiovox alarm
  • Locate the push-button LED switch on the alarm box under the driver's side dash. The small red or black button is used to manually disable the alarm.
  • Put the key in the ignition and turn it to the "on" position. This activates your vehicle's battery, but doesn't start the engine. Press and hold the push-button LED until the LED light stops blinking. Once the LED stops blinking the alarm is disabled until you manually reset the alarm.
  • Start the car. Then, press and release the push-button LED switch once, to reset the alarm.
Apr 01, 2017 | Audiovox Vehicle Parts & Accessories
How to turn off alarm on Mac book pro?
  • If you want turn off alarm by one Click for you wake up than Go to Alarm Clock >Preferences > Advanced menu and set turn of by one click.
  • if you are set up calender alarm and go to that timer and disable the event that you want to disable.
but if you are looking for other alarm to turn off than take http://www.apple.com/support/ . you can set different type of alarm in your system for different events so know more about Mac Customer Service .
Jul 24, 2014 | Computers & Internet
2001 mitsubishi eclispse gs wont start how do you bypass the security system
  • 1 Turn the ignition key counter clockwise in the driver's side door to unlock the caricon1.png. This deactivates the alarm long enough for you to gain access to the vehicle. Then, place the key in the ignition and turn the key until it clicks once. This starts the car's battery, but doesn't ignite the engine. The LED light on the dashboard should stop blinking, indicating the alarm is temporarily disabled.
  • 2 Locateicon1.png the box for the alarm under the dashboard on the driver's side of the car. Then, look for the override button on the box. Typically, the small button is either red or black. With the ignition key in the "on" position, press the override button and hold it in until the alarm chirps once. This disables the alarm until you manually reactivate it.
  • 3 To reactivate the alarm, turn the key to the "on" position and press the override button once. The alarm chirps twice, indicating the alarm is active.
  • Hope this helps!
    Mar 15, 2014 | 2001 Mitsubishi Eclipse
    Car alarm goes off when unlocking door
    You will needs to think of it this way. Once you set your alarm it is looking for the corresponding signal to disable itself. That comes from the fob. If you don't use the fob and just use the key, the alarm system is doing its job and alerting you since it has not received the disable command from the fob. Either lock the door with the button when you exit the car if you want to use the key or use the alarm fob. This will also happen if you use the car manufacturers fob to unlock the car if you have locked it with the alarm manufacturers fob.
    Hope that helps - I have hidden all of my original car fobs to help alleviate this problem!
    Dec 29, 2013 | Cars & Trucks
    HOW TO DISCONNECT FACTORY ALARM IN A 03 accord...
    hi
    once you unlock the vehicle leave the door open
    locate the factory alarm box under the dash or side of the dash
    find the fuse and remove it
    13352118-extj4arg1t42xbh3l3byl5v2-3-0.jpg remove the blue fuse where the red wire runs into this will disable the alarm
    cheers
    Jun 26, 2012 | Honda Vehicle Parts & Accessories
    How do I turn off the alarm clock
    Hello
    The unit has 2 alarms (alarm 1 and 2). They can be used
    together or independently. Alarms 1 and 2 have different
    sounds so that you can differentiate them. The alarm will
    sound for 1 minute unless it is disabled.
    To set the alarm:
    Navigate to "Set Alarm" setting mode as shown in the
    Changing Settings section. The order of the settings is;
    alarm 1 or 2, hour and minute.
    To enable or disable the alarm:
    • Press MENU until you reach alarm 1 or 2 display.
    • Press [UP] or [DOWN] button to enable or disable the
    alarm. "-:--" means disabled.
    OK.
    Sep 14, 2011 | Oregon Scientific WR108 Weather Radio
    How to disable 2000 elantra car alarm
    ok are you ready, first turn the ign on but do not turn the key to the start position, the alarm should sound, as soon as the alarm stops sounding, count 10 seconds then start the vehicle,this will disable the alarm unless you set it with the remote, if that doesent disable it repeat above again it has to be 10 second count after alarm stops..
    Oct 21, 2009 | 2000 Hyundai Elantra
    I have the Python 872 Alarm on my 95 Acura Integra and this morning I couldn't get my door to unlock. I kept pressing the unlock button, but the Function key light would come on and not unlock it. What can...
    to disable the alarm, you would 1st need to know where the valet button is. It is usually underneath the dash. What you do is u open the door and of course the alarm is going to be set off you quickly turn the key to the on position and press the button once and then wait, then the alarm should shut off and now you can start your vehicle. Thats the standard procedure for the DEI alarms. For some reason it doesnt disable it then your other option would be finding the alarm brain and pulling out both fuses. One is for the lights and other is for the main power to the brain, i say pull both to make sure you have successfully killed the power to the alarm
    Jul 15, 2009 | Vehicle Parts & Accessories
    Alarm for audi A4
    Try disarming the car from the trunk. Sounds like the door lock switch is not deactivating the alarm, which it should, with or without the remote.
    Apr 24, 2009 | 2001 Audi A4
    Bose Wave Radio Logo
    1,061 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
