Question about Motorola Mobility RAZR V3
Motorola razr won't turn on - Motorola Mobility RAZR V3
Motorola razr v xt885 turned off and won't turn back on, even when it's connected to power
same problem have no idea how to fix it can you fix it is it possible to turn it back on?someone please helppp! i tryed looking up on google and youtube havent found much
Jan 29, 2013 | Cell Phones
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
I've got a Motorola RAZR 3 or 4 years old. I just bought a new car with Bluetooth (Ford Sync). How do I get the car to recognize the phone?
In order to make other devices see your motorola mobile phone, you should enable "discovery mode", which is activated in Bluetooth menu of your phone.
Please be aware that this feature is turning on only for 3 minutes, then new devices won't be able to find your cell phone. If 3 minutes is not enough, you can activate this feature again (and again).
This procedure is only required for initial pairing, there is no need to perform this operation every time.
Hope this helps!
Sep 07, 2011 | Motorola Mobility RAZR V3
Blue screen, says Bootloader USB Init at bottom, won't restart with power key
1.go to http://www.modmymobile.com
2.download p2ktools zip file
3.extract zip file
4.down firmware for motorola razr v3 zip file
5.extract razr v3 zip file
6.open p2ktools extracted folder open p2ktools exe file
7.read help how to flash your motorola razr v3
Aug 24, 2011 | Motorola Mobility RAZR V3
The screen is blinking white on and off it won turn on
you must off spilled water into it or someone and u are going to have to get it repaired then
Feb 14, 2010 | Motorola Mobility RAZR V3
Motorola Razr V3 - not turning on
your main-board needs to be tested
May 23, 2008 | Motorola Mobility RAZR V3
Bluetooth message is "unable to connect"
has the two phones been syncronized if so what file format are they in as most wont work on newer phones
Jan 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Key Pad Doesn't Work
you need to change the flex cable as well as taking the phone to a mobile repair center and have it fully service.
Dec 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
197 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
