Question about Fluidmaster Plumbing
My Fluidmaster Leak Sentry 400LS did not come with any instructions. I would like a copy of the instructions.
  • 653 Answers
Here you go.
http://www.fluidmaster.com/html/float_products_intl_400.html
Posted on Oct 09, 2009
I am installing fluidmaster 400arha fill valve, but am unable to adjust height. Lower shaft rotates both directions, but does not click or change height.
I had to retrieve my instruction sheet answer this. According to Fluidmaster, you may not hear clicks as you adjust. As I recall, you have to apply upward pressure on the unthreaded shank as you twist the threaded shaft. As you have no doubt found out, the instructions and illustration 6. are vague about this. Good luck and happy flushing!
Feb 18, 2017 | Fluidmaster Plumbing
Youtubecouk
Leaking to drain? Adjust float height to keep water below overflow ... or change flapper if it doesn't seal.
Leaking to floor? Check either end of supply line; or check seal between tank and bowl.
Aug 22, 2014 | Fluidmaster Leak Sentry Water Saving...
Doea a Fluidmaster leak sentry fill valve stop the water from filling the tank if it cracks to avoid flooding my house?
Install the FloLogic System, a whole-house leak detection and water shut off valve. You will sleep better knowing your home is protected 24/7
Sep 19, 2011 | Home
Seems to leak water out of the top of the 400a unit
Fluidmaster suggests cleaning the valve per the instructions #12 - 15:
12. IMPORTANT: Always clear sand and rust from system. Make sure
water supply is shut off. Remove valve TOP by lifting arm and rotating
top and arm 1/8 turn counterclockwise, pressing down slightly on cap.
13. While holding a container over the uncapped VALVE to prevent
splashing, turn water supply on and off a few times. Leave water
supply off.
14. Replace TOP by engaging lugs and rotating 1/8 turn clockwise. MAKE
CERTAIN TOP IS TURNED TO THE LOCKED POSITION. VALVE MAY
NOT TURN ON IF TOP IS NOT FULLY TO THE LOCKED POSITION.
15. Turn on water supply. Adjust water to desired level by squeezing water
level adjustment clip and moving FLOAT CUP up or down along stainless
steel link. Check for leaks, then check for proper flush.
If that does not work:
IF FILL VALVE WON'T TURN OFF,
• There may be debris at seal - repeat Steps 12-15.
• The seal inside the valve top may be damaged -replace with genuine
Fluidmaster 242 seal.
Nov 27, 2010 | Fluidmaster Plumbing
After tank fills up, water continues to flow a little. How do you fix it?
Replace the top cap of your fill valve, or just the fluidmaster seal disc. Here is a link to the Fluidmaster fill-valve Instructions.
Sep 06, 2010 | Fluidmaster & Fits-All Faucet Connector
Toilet gasket fluidmaster 7500c instructions
Fluidmaster has an instructional PDF file that I found clear and concise. Find it here: http://www.fluidmaster.com/pdfs/7500_instructions.pdf
Hope this helps.
Oct 09, 2009 | Fluidmaster Plumbing
I am looking for feedback about the Fluidmaster
You will be fine to use the fluidmaster. 400ls. all toilets should use them. hope this helps. duane.
Sep 30, 2009 | Home
I have installed a fluidmaster 400 bottom inlet
I have installed 400A or 400LS valves on systems as low as 30psi, but below that I don't know that it would work very well if you needed it to fill faster.
Keep in mind that your pressure to the toilet will be 1/2psi for every foot above the fill level of the tank, which is reduced by friction loss in the pipe and fittings on the way to the toilet.
Sep 27, 2009 | Fluidmaster Plumbing
Plumbing Logo
987 people viewed this question
Top Fluidmaster Plumbing Experts
Jim Goldsmith
Jim Goldsmith
Mack Baxter
Andrew Bugbee
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
