Question about LG Shine KE970 Cellular Phone
How do you change the charge connector on an LG Shine?
Does this part need to be soldered or snapped in?
Battery on lg shine not charging and not showing how much battery life is left
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 02, 2012 | LG Shine KE970 Cellular Phone
My phone wont charge lg shine
Change your battery. If you have replaced it recently then take out the battery, rub it n place it back. This works for me. Good luck!
Feb 22, 2010 | LG Shine KE970 Cellular Phone
Charger port on LG shine broke.
It could be either your charger is broken or the charging port in the phone is- I would recommend taking it to a store and have them check it out for you.
Jan 30, 2010 | LG Shine CU720 Cellular Phone
I can't charge my lg mobile on the mains or on the computer
It seem the charging port is faulty, you need to replace it for your lg mobile to charge again.
Also confirm if the lg mobile charger is still working so the we can both be sure it the charging port.
Take care.
Dec 04, 2009 | LG Shine KE970 Cellular Phone
Broken charger slot
You need to change the charger port. You can do it by yourself, all you need is a set of soldering tools, tweezer and a new charger port.
Nov 07, 2009 | LG Shine CU720 Cellular Phone
I need help replacing the Charge port on an Lg Shine.
you can take the phone apart again and gently pull the pins slightly out of the connector enclosure with a sewing pin. this could ensure proper contact due to the metal's elasticity (would have them act like a spring)
Aug 31, 2009 | LG Shine KE970 Cellular Phone
LG Shine Charge Connector
You didn't told me that if your cell phone is under warranty. But i will take it as that it is under warranty . You should contact LG priority dealer or to that person form you have purchased the cell phone they will repair your phone free of cost and you will get it back within 5-6 days.
Feb 12, 2009 | LG Shine KE970 Cellular Phone
Need an unlock number for my lg shine cu720
Enter at power on after putting in chip.
*# 865625#
Then yes and put code 2 times
Unlock Code for lg shine
8817 9873 8974 4496
Aug 13, 2008 | LG C2000 Cellular Phone
Lg 8500 wont charge
you could cut the plug of your battery chrger and take the wires black and red wires and take the battery and touch the black wire to the negitive side and red to the postive there should b 4 gold bars (were u touch the wires to) u need to use the outside two not the midle ones then tape them down not covering the middle ones with tape put the battery in the phone and tape it make sure the middle gold bars arnt being touch it will not work
Jun 11, 2008 | LG Chocolate Clamshell VX8600 Cellular...
How do I change message tones on LG Shine?
how do I change message tones on LG Shine?
May 25, 2008 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
