Question about ViewSonic VP201b 20.1" LCD Monitor
Monitor distorting in screen halves after warmup
I have a Viewsonic VP201b monitor that's been acting weird for the last several months. After the unit has warmed up (clearly a temp-related component problem,) the right half of the screen will start to distort, waver like it's under water, then bail out altogether into vertical gradient-like stripes echoing the colors of my background graphic. If I power the monitor off and on again the stripes will have changed to vertical black and white stripes.
After several minutes that half of the screen will go back to watery and wavering, and occasionally go back to normal function - for a few minutes.
A couple months after the right half began doing this, the left started the same thing - now the HD on that system also died so I'm just using my laptop.
I'm thinking there's some simple component that's got a temperature-related longevity problem. I got the VP201b for around $350 (after cashing some of my employer's award bonus certificates against the original $750 price.) I'm wondering if there's any point to having the thing repaired vs. just junking it and springing for a new one.
Thanks!
    Scholar:
  • 146 Answers
It probably isn't worth repairing as the cost will exceed what you would spend on replacing it.
Posted on Sep 11, 2009
Testimonial: "That's what I was afraid of. I've considered pulling it apart and troubleshooting myself, but I'd need a schizmatic and don't know where to get one."
Viewsonic vp201b pink tint on screen
That sounds like possibly a bad cable or a bad video card. Do you have another cable you can try?
Dec 01, 2012 | ViewSonic VP201b 20.1" LCD Monitor
How to degauss viewsonic vp201b lcd
You do not degauss LCD monitor, it does not use electron beams (affected by magnetic field, if the showdow mask is magnetized, it can mees up color display) for making pictures like LCD.
You only degauss CRT type monitor.
http://en.wikipedia.org/wiki/Degaussing
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | ViewSonic VP201b 20.1" LCD Monitor
Hi, I have a ViewSonic VP201b monitor that has a problem.... It seems that it wont turn on (BLACK SCREEN *NOTHING*). The yellow light goes on when idle, but when it's not idle the green light isn't...
Get a working monitor and turn on the computer. Then swap the monitor with VP201b.
Get a flash light closer to the screen to see whether you can see the desktop screen image. Yes? Then it is your backlight inverter.
Find a Youtube video to show you how to open the cover. Then look for any sign of broken capacitor(s). Replace them and then test your monitor. If all capacitors are okay, it is one of your FUSES. There are 2 tiny surface mount fuses ("FN" type). You can short the two ends to test it before removing them. Often only one of them is broken. Replace it and the monitor shall be okay now.
May 12, 2017 | ViewSonic VP201b 20.1" LCD Monitor
ViewSonic VP201b with a black screen
hramirez, Retevo. com says time to retire this old monitor. Its that or you will need to do some extensive reading here on fixya on how and what to look for inside the unit that could be causing your black screen condition!!! Then you will go to YOUTUBE and view some of the many video clips that deal with "lcd monitor repair" and lcd monitor disassembly". Have you noticed any bad, swollen top, elcetrolytic filter capacitors on the units "switch-mode-power-supply/CCFL inverter printed circuit board?? How about any "cold" frosty looking solder joints around the component leads of the power transistors and ferrite inverter transformers? May need to get large magnifying glass to find those pesky little cold solder joints. 12fixlouie
Jul 26, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Vp201b wont turn on
Checkto see if you do have 12vdc output from the power supply module as shown in my pictures: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VP201B/
Look for bad caps (leaking/bulging tops).
May 19, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Display flickers than scrambles.
Most likely loose connection at PC. Check that monitor connector pins are not bent. Ensure that he monitor plug screws are screwed into the connector to prevent plug movement, at the PC and in the case of some monitors, also at the back of the monitor. If this does not correct the problem, there is probably a fracture in one of the solder joints on the VGA board at the connector.
Mar 19, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Screen jumps back to prior screen
If you mean to say that the computer-generated displayed image on your screen changes, it's a function of the computer, not the monitor. If you mean to say that some monitor-generated displayed image is appearing (such as a setup/configuration menu or a splash screen), please tell us more so we can diagnose further.
Sep 12, 2009 | ViewSonic VP201b 20.1" LCD Monitor
Sporadic Discoloration & Distortion
Most of these monitors have a 3 year warrantly. Give them a ring and see if they will exchange it. No harm in trying!
Mar 22, 2008 | Acer AL1912B 19" LCD Monitor
ViewSonic VP201b 20.1" LCD Monitor Logo
250 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
