Question about KVH TracVision A5 Car Video Player
Reciever serial # 050101523 Antenna serial # A04110263 The unit has been installed and used on a limited basis for about 3 years. My problem is the unit, when turned on makes a series of beeps as in "Beep Beep beep" Then the angle adjuster goes up and down a couple of times, then the unit on antenna turns around several times. It comes to a stop and the receiver emits another "beep" and it does nothing else. We have the vehicle in the our shop where it gets no satellite view and would normally continue to rotate until turned off. Outside it does the same thing - stops without finding a satellite. We have taken the top off the anntenna and every thing looks good therein.
  • jim264 Sep 11, 2009
    All is well and working.
    Batteries in remote were the problem.
    Unit was turning on manual, doing a short check then going into standby mode.
    New batterires solved the problem.
    Thanks
    President:
  • 1,462 Answers
Although not familiar with this brand at all but by similarity I can tell you that the loader software has got a problem. Depending on the connectivity on the back of this satellite receiver you might be able to connect it (probably by RS 232) to a serial port on your computer and re-upload the software, definitely you would have acquired the software for this make and model as well as a 9pin serial Null modem cable.
If you doubt your capability check with a serviceman how much he will charge you as it might be the safer way to go.
Get back to me if more help needed.
Good luck
RNJ VINOD KUMAR
Posted on Sep 11, 2009
    New Friend:
A-5 receivers will power up (or not) depending on their last power on state. If your remote,-or your RF to IR converter is not working,- AND your last antenna state was powered off,- then it will do a short antenna check (power on) - and then it will power back off to the last state of use. this is normal. NOT a software issue.
Posted on Sep 01, 2013
What are the installation colors for the of the plug?
I can't locate a manual for that unit. Look here for standard color codes:
http://www.the12volt.com/caraudio/headunitharness.asp
May 05, 2014 | Pioneer GM-5200T Car Audio Amplifier
I have used the Gpsmap 178c for about 3 years now. Recently I have started be unable to find satelites, wass on or off. Once in a while it works. presently I get no satelites I would buy a new antenna...
Based on the problems I have seen with this unit the problem is the reciever circuit not the antenna, so you should consider a new unit, Garmin charges a fortune to repair these.
Sep 22, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
My sirius reciever in my boat worked fine until this year now it wont work antenna is only two years old and it is a high quality marine antenna could it be the reciever it is hooked to a clarion radio...
Oxidation from humidity could have tarnished a connector somewhere. Make sure all connectors are clean and shiny first. It could be that the receiver is bad. A stereo shop should be able to check that for you easily.
Mar 13, 2010 | Clarion (NAVSIR) SIRIUS Radio Receiver
When antenna is open screen starts flipping out of control
TRY USING AN EXTERNAL ANTENNA. THIS SOLVED MY SIMILAR PROBLEM.
LENN
Mar 20, 2009 | Garmin iQue 3600 GPS Receiver
Can't find the voltage specs for terk 9330 tower fm antenna
Product Specs: General: Product Type Radio antenna Recommended Use Indoor Width 3 in Depth 16.9 in Height 3.5 in Color Black Localization English Antenna: Wave Band AM, FM / FM: 87.5 - 108 MHz, 540 - 1700 kHz Impedance 75 Ohm Gain Level 42 dB Amplifier Built-in Included Accessories Connector coupler, impedance transformer Connections: Connector Type 1 x FM antenna ¦ 1 x AM antenna Power: Power Device Power adapter - external Manufacturer Warranty: Service & Support 1 year warranty Service & Support Details Limited warranty - 1 yearlet me know how this works out for u
Jan 31, 2009 | Audio Players & Recorders
ERROR: Antenna Not Detected
My PNP2 unit has a few of the prongs missing where the antenna mount connects to the back of the reciever, when its in my car, i usually just pull the reciever out of the craddle just a small amount and it usually gets a connection. When its in my home dock, I use a bent credit card at the top to pry it out just a little to get a connection. Its a pain but seems to get it working.
May 23, 2008 | Audio Players & Recorders
Acquiring signal only on display
If under warranty get a replacement. If not, you are beat, they are dead when they stop getting signal and you have tried different antenna. It's sad but true.
Jan 21, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Antenna
I, my brother and a guy at work had the same problem. I don't know how it happends but your antenna went out. You need to get a new one.
Oct 14, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Digital Reciever Issues
I have the exact same problem.Check this out. http://www.fixya.com/support/t209330-lg_dat_250 Unfortunaley, for temporary use of other channels other than abc & abc2, you need to pull out the antenna lead when it is trying to program those stations back in. My serial number starts with 601, does yours?
Sep 30, 2007 | LG LH-D6230 System
CANNOT READ ANTENNA
I had a similar type problem where i have a lifetime subscription and my XACT VISOR XTR3 unit had a faulty power connection that was driving me nuts. i decided to try and swap out the internal receiver component with a new unactivated unit i bought on ebay. (all the types are out there and pretty cheap even for new)
in opening the new one up i found the only difference from unit to unit is the receiver brain inside the unit, and it is relatively easy to swap out the brain into the body of a new unactivated unit. just four small screws and carefully pull the brain out of the long multi-pin connector. i put the old brain into the new carcass, screwed it back together and it works like a champ. just have some patience in figuring out exactly how your particular unit comes apart, and you will need small screwdrivers and either a small allen-key set or torx set - my old unit had the allen-key screws on the outer case and the newer one had torx screws.
Aug 10, 2006 | Xact Communication XTR1 SIRIUS Radio...
KVH TracVision A5 Car Video Player Logo
107 people viewed this question
Top KVH Car Audio & Video Experts
xxxxxx xxx
Are you a KVH Car Audio and Video Expert? Answer questions, earn points and help others
