Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Red light flashing
I have a sony wega red light flashing 3 times every 5 seconds
  • d8rba Sep 11, 2009
    model no.kv-32fx68u wots the lamp door (novice)
  • Anonymous Mar 23, 2014
    red light flashing 5 times
  • 4,234 Answers
DO NOT under any circumstances touch the red wire inside the set. This cable connects to the picture tube and carrys 33,000V and can cause injury. The 3 blinks are a diagnostic code that indicate the defective circuit. Please confirm the model number as KV-36FS120 and I'll look up the code.
There is no Lamp door if this is the KV model mentioned above as this is a CRT based set not a projection set.
Please confirm the model number so I can get you a proper solution.
Thanks,
Dan
Posted on Sep 11, 2009
  • ABRsvcs Sep 11, 2009
    There is no lamp door on your model because there is no lamp. Thank for confirming the model number. When I get back to the shop, I will look up the code and update this again.
    Dan
    Problem Solver:
  • 12 Answers
3 flashing light on a Sony typically indicates an open lamp door on the back of the set. If the door is properly closed it could be the lamp door switch.
If you find this is the case you will need to unplug the set for 1 minute after properly closing it and allow it to reset.
The other potential fault is a faulty IC inverter board.
    Problem Solver:
  • 5 Answers
YOUR PROBLEM IS VIDEO SECTION.
CHEK THE VIDEO OUT TRANJESTOR RED CATHORD
AND CHEK THE CRT RED CATHORD IMEDETLY SHORT MACRO SECOND
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
RED FLASHING LIGHT
sir
these are the causes for 5 red blink in your modal
Video OUT (IC1545) is
faulty. (A board)
• IC001 is faulty. (A board)
• Screen (G2) is improperly adjusted
thanks
Oct 03, 2017 | Sony Televison & Video
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Dead sony
The $1200 was for the lcd engine not the lamp. You should change the lamp. The buzz is the power supply trying to light the lamp.
Apr 25, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
279 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
