Question about Fender Audio Players & Recorders
I have a new '65 Deluxe reverb Reissue Fender Tube Amp and I'm not getting power to the amp after I plug it in and turn it on. Ive checked other things in the outlet and they work, so it is not the outlet. Could it be the amp fuse? I pulled that out to see but dont know what to look for. I am relatively new to the electric guitar world, so hopefully it is something simple that I am overlooking
  • tmcgraw1 Sep 11, 2009
    hi tswiercinsky.....no power as in no lights on the amp...similarly, the tubes are not warming up or glowing either....dead in the water....no sound
  • Tim Swiercinsky May 11, 2010
    No power, as in no lights on the amp, (or the tubes inside not glowing) Or, no sound from speaker.
    Master:
  • 350 Answers
To test a fuse use tge continuity setting a multi meter or sometimes you can visually see if it's blown, burn marks or the small wire in side fuse is gone, also this amp has a power and standby switch, really hope this helps?
Posted on Mar 03, 2015
  • 37 Answers
If you have power and a good connection to the guitar, don't take it apart - take it back. It has a warranty and any reputable dealer will give you another one - just ask for a test before leaving the store/shop.
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: fender deluxe reverb
Hi Hoopnholler
I would start by changing out 12AT7 (V4), is a common buffer stage to the vibrato and reverb audio path. If you have trouble identifying it, you can just swap out with a known good tube and see if it resolves your problem.
If that does not help, then time to go see an amp doctor. If youy are inclined. here is a circuit diagram that you may find useful in faultfinding the problem yourself.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 19, 2008
  • 94 Answers
SOURCE: I do not have a manual for my Fender deluxe reverb
Please click on 'Download the complete
user guide (2645 Ko)
" on the right middle of the screen and complete the survey to download it .
http://safemanuals.com/user-guide-instructions-owner-manual/FENDER/65%20DELUXE%20REVERB-_M
Posted on Sep 26, 2009
snakehead
  • 1074 Answers
SOURCE: loud buzzing noise when I turn amp on -won't go away
change the plugs on the chords.or both.they loose their resistance.good luck.
Posted on Feb 28, 2010
I replaced Can I change the tubes on my fender blues deluxe reissue from 6l6 to 6v6 power tubes
An internal component has failed. Without it in front of me for testing I cannot say which. You need to takje it to the repair shop.
Jan 28, 2016 | Fender BLUES-DELUXE-REISSUE Tube Guitar...
Is there any way to use a heil talkbox with a fender '65 deluxe reverb reissue?
No - you use these with a microphone. Plug you guitar into the Heil, put the tube in your moth and sing into a mic while playing. You CAN plug the microphone into the fender amp, but a PA system is better
Oct 15, 2013 | Dunlop Ht1 Heil Talk Box
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
Twin tube amp. power comes on, no sound. replaced tubes, still no sound
Do you have the speakers connected properly?? If so, maybe speaker wiring needs checked.
Feb 19, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
My Fender Hot Rod Deville reverb is not working. What should I look for in trying to fix this problem
There are two coils in the reverb unit which use delicate wires which can break off - these can easily be checked, as follows:-
i) Remove one cable plug from the reverb unit & substitute an uncapped phono plug to the socket.Then check that there is electrical resistance across the plug terminals.
ii) Reconnect original phono plug & do same test as i) to the other socket.
iii) If either is open-circuited, then look for a break in the lead-out wires from the corresponding coil inside the reverb unit.
This break may be repaired (contact me for details) or buy a new reverb unit!
iv) If there is electrical resistance at both sockets of reverb unit, then clean both original phono plugs & try the system again.
Sep 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have a brand new fender deluxe combo amp is the preamp in and out usable for an effects loop
Yes you could do that. The preamp output is just a BUFFERED output of the signal sent to the power amp. And the power amp input jack is BUFFERED before driving the power amp. These impedances are neither high or low being in the 1K to 3K ohm range.
The jacks for BOTH are mono jacks so noise pickup is possible if long cables are used. The external effects unit should be well grounded and operate off the same receptacle as your Fender for system safety. Use SHORT audio cables to minimize noise.
ALL the signal will pass through the effects unit when used this way... HOWEVER the internal reverb will still be in this path. You can kill this by turning the reverb control to zero on the Fender.
May 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Apr 24, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Loud buzzing noise when I turn amp on -won't go away
Feb 28, 2010 | Fender Audio Players & Recorders
216 people viewed this question
Top Fender Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rick Moore
Rick Moore
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
