Question about Frigidaire GLEFM385D Electric Kitchen Range
Oven will not bake properly
My top oven will not bake properly. Cakes come out dry and when heating frozen french fries, they come out overdone when heated per instructions. I have checked the oven temp with an oven thermometer and the temperature is consistantly correct.
Any ideas on a solution will be appreciated.
  • 126 Answers
As i have said before cook times are only a guide as all ranges in different locations cook differently! get to know your stove
Posted on Dec 10, 2007
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
I am having nothing but problems with baking cakes and cupcakes in my new gas oven
Are the mixture quantities ok ?
Are the ingredients properly mixed ?
Nov 07, 2013 | GE Cafe CGS980S Kitchen Range
Wall oven is not baking properly
Look in your Owner's Guide to see if the unit you own has a way to configure or calibrate the temperature yourself before contacting a professional.
Jul 18, 2012 | Frigidaire Ovens
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
Oven with convection - when baking cookies, cakes, etc they aren't getting done. Bottom and middle is soggy. Both coils look to be heating, convection fan is working.
Set the temperature one position higher. Convection ovens have a more even heat spread so if you used to bake at the top of your old oven it will now be slightly lower temperature
Dec 06, 2009 | GE Profile JB900BK / JB900KK / JB900TK...
Frigidaire range model #FEFLFSA, is the top element
When you say Top Element, I assume you mean the TOP OVEN ELEMENT, correct? You have bake, and broil? Bake is usually on the bottom, and broil is the top. In order to have the oven operate correctly, the top and bottom elements may come on at start, in order to do as you just said, "Preheat the oven". This will insure an even distribution of the heat in the oven box and result in better cooking expierences. I would not be alarmed or concerned if the top element came on for a short period to pre-heat in preparation for cooking. This is normal. If the top element stayed on, and did not shut off on bake after the pre-heat period, then I would say you have a control board problem. However, if it comes on and then goes out, except when you are broiling, then I would say that this is normal for your stove, and the pre-heat mode of operations. Your owners manual should advise you of this very process in the guide section to how to use the oven. I hope this helps and that all your cakes, pies, souffle's and the like are......delicious. I'm sure they are. I hope this helps and eases your concerns. Kindest regards, Slats.
Sep 25, 2009 | Frigidaire Kitchen Ranges
Best setting for baking cakes
good day,
hope this link below will solve your problem.
baking.
The best bread machine we've found for gluten-free bread baking. Programmable feature puts you in charge. Bakes a delicious 1.5 to 2 pound loaf every time. It has a viewing window, automatic settings for breads, cakes and jam, sourdough starter and programmable cycle that makes gluten-free bread in under two hours!
Aug 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Heating
Some Deep Fryers heat up faster than others, please see details below for pre-heating times: Non-Immersion Element (No element in the Oil): 25 to 30 Minutes Immersion Element (Element in the Oil): 7 to 10 Minutes Are you by any chance overloading the fryer? try smaller batches. Preheat the oven to 180 to 200 F. Heat the oil in the fryer to 280 or 290 F. In small batches appropriate to the size of the fryer (fries for a serving of 4 people may need to be divided into 2 or 3 groups), fry each batch for about 8 minutes at this temp. Remove to a holding bowl. They will look limp, nasty and oily. (This uses 1/4" square fries from baking pototoes cut with a standard mandoline.) When all the fries have been precooked, increase the oil temp to 375 F. Add the fries back to the oil in the same sized batches as before. It will take 3 to 5 minutes for them to crisp and brown. Drain, salt, and move to a cloth-lined bowl and hold in the 180 F. oven. Let the oil temp recover to 375 F. and cook the next batch in the same manner. Repeat, holding interim fries in the 180 oven, until all the fries are done. When all batches are done, toss to distribute salt and the new fries with old, and serve immediately. Properly done, all commercial french fries pale in comparison to these. However, I cannot guarantee that this method works with frozen commercial products. I always use fresh baking pototoes. That said, the frozen product should work to its optimal advantage when done in small batches with the first batches held in the warming oven as the other batches are done. If it still doesn't reach 300 F then by all means take it back to the shop and ask for a replacement. If you're out of warranty get an estimate for a repair. Good luck and bon apetite ;]
Jan 24, 2006 | Black & Decker DF200 FryMate Fryer
Frigidaire GLEFM385D Electric Kitchen Range Logo
229 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
