Question about Denon CDR-M30 CD Recorder
CD isn't finalized
Good Morning,
When a CD says it isn't finalized, is that saying it can still be recorded on and can still be played on a variety of machines (or will it only play on the same machine it was recorded on)? My DVD, when it isn't finalized, can still be recorded on, but may not play on any other machine than the one it was recorded on. I'm not sure if the same applies to a CD.
Thanks!
Jackson
    Problem Solver:
  • 17 Answers
No that means that the cd wasnt fully burned before ejected and you can still finalize it if you put it back in the device that started burning it it will do it
Posted on Dec 10, 2007
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
I have a problem to finalize cd after recording
On my CD recorder when it enters the finalize mode it first writes the PMA, after that mine gives a readout of the time it will take to finalize, after all that you need to hit the play button to write to the disk.
I don't have your exact unit but I supect you need to push an additional button to get it to start writing to the disc to complete the process.
Feb 27, 2012 | Tascam Cd-rw900sl Cd Recorder/player
TDK DA-5700 records from cassette to cd-R but nothing happens when I press FINALIZE and then PLAY (ENTER). Why?
Finalize is for multiple recordings. If its a single recording, its finalized by itself.
Feb 09, 2012 | Audio Players & Recorders
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
How do i finallize disk with my tdk da-3826 dual-cd recorder
Press the Finalize button (and it will start flashing) and then press Play button right away (the finalize light will stop flashing and be a steady light).
Once the disc is complete the CD-R light will change to CD.
Dec 23, 2008 | TDK DA-3826 2-Disc CD Recorder
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Nov 25, 2007 | Koss CDR200 2-Disc CD Recorder
Won' record
Check your wire they could be damage
Apr 04, 2007 | LG ADR-620N CD Player
Denon CDR-M30 CD Recorder Logo
73 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
