Question about Sony 4-660-223-01 Touchpad Keyboard
Touch pad too sensitive, it always messes me up when I'm typing
    President:
  • 1,015 Answers
You could try adjust the touchpad settings. Sometimes there is a touchpad icon in the taskbar that you can right click on to adjust the properties. You can also disable the pad and use a USB mouse instead.
Posted on Sep 11, 2009
  • 2,567 Answers
1. Go to "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, find the "Sensitivity" setting. Try changing this setting to lower the sensitivity of the touch pad to the degree you find acceptable.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
Posted on Sep 12, 2009
Touchpad too sensitive
Click Start/Control Panel and look for the mouse or touchpad. Go into the touch pad and you can adjust all kind of things. Don't worry about messing something up, you can always set it back to Default.
Apr 05, 2012 | Computers & Internet
Typing on a DELL Inspiron 1525 keyboard, the typing often appears somewhere else to the left on the line or a couple of lines up.
This problem can be very frustrating! It is typically from you hand moving over the touch pad to type on the keys. It would be lovely if they weren't designed so. To reduce the problem change the sensitivity of the touch pad to a lower level so it is not as sensitive.
Mar 04, 2011 | Dell Keyboard for Inspiron 1420, 1520,...
The touchpad is so sensitive I can't control it
You've got it, your touching the touch pad, annoying isn't it.
You can try a couple of things,
1) Go to Start - Control panel - Mouse/Touch panel - and see if you can reduce the sensitivity or,
2) Disable your touch pad (Same route) and use an ordinary mouse instead. That's what the wife does.
Jul 09, 2010 | Toshiba Satellite A100-S8111TD Notebook
Pavilion DV4000 has always done this. While typing, randomly will jump up a couple of lines and the text will be typed in a sentence above the current line being typed... Does this make sense ?
You might be brushing the touch pad with your palms when typing. Some hp's have a little bar above the pad to turn it off while typing. The other option is to go into mouse under control pannel and look for a sensitivity adjustment.
Jun 17, 2010 | HP Pavilion dv4000 Notebook
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
When i am typing the cursor will suddenly move to the middle of what i have already typed , it is driving me potty and i have to keep re typing things , is there anyway to stop this? sunshine
I was experiencing this problem before, and I figured out I was tapping the touch pad with the palm of my hand. I had to download a driver for my touch pad and adjust the sensitivity of the touch pad.
Mar 01, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
Acer 5620 touchpad
Function F7 to disable the touch pad and the same buttons to enable it. The function key is the button with Fn. on it.
Good luck and don't forget to rate my answer.
Jan 11, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Speed strip on touch mouse is too sensitive
remove the touch pad software if u have any installed for the touch mousepad
Nov 24, 2008 | Computers & Internet
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Computers & Internet Logo
2,212 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
