Question about Dewalt Mitre Saw Workstation
What type of mitre saw blade for Pine Casing?
What type of 71/4" mitre saw blade do I use for cutting Pine casings/trim?
    Sergeant:
  • 384 Answers
Fine tooth or plywood cutting blade.
Posted on Sep 11, 2009
Slows down and stops when trying to cut hardwood
You just do not have a saw that has enough power, the blade is dull or both. Change your blade and push the wood through slower or get a more powerful saw for the hard woods.
May 11, 2016 | Delta Saws
How to square up my saw and where I get a copy of the manual
With the saw unplugged manually pull the blade guard fully open and use a strong elastic band/string or otherwise wedge it open to give yourself full access to the blade.
Use an engineers square or at a push a good carpenters combination square measure the angel between the blade and the saw bed. you might find it's slightly off 90 degrees.
Ok, depending on the make of saw there will be a screw thread at the front or rear of the blade on on or close to the pivot points (where the bed tilts to allow different angles to be cut). it usually has a loking nut. Slacken off the locking nut and also slightly slacken off the tilt adjusting screws. You should be able to easily move the bed in relation to the blade. You will see the bed hitting the bottom of the adjusting screw.
Gently turn the screw and keep measureing the angle with the square. Make sure that the squares blade is tight to the saw blade and not touching the small tooth at the edge of the blade. there should be absolutely no gap either on the saw blade or saw bed when its correct.
Holding the screw with one tool getly tightedn up the locking nut ensuring that the main screw does not move.
CHeck everything again and tighten up the tilt mechanism.
Let me know with pictures if you need more exact info for your saw model and I can point out the parts.
Sep 13, 2014 | Saws
Mitre saw cod211lsm
Few budget tools and especially generic, brand engineered tools imported from the far east are superbly accurate but tend to be "near enough".
You didn't say whether it is a hand operated mitre saw or a power saw.
Most power mitre saws have a number of stops that can be adjusted or filed in order to calibrate the angles and this process should be done when the saw arrives. Once both 45 degree angles have been calibrated accurately the angles in between should fall into place fairly well.
One problem with low cost mitre (chop) saws, even some so-called professional saws is the construction is so light, when pulling down the handle the machine flexes and spoils the cut. This is especially true when the handle is not set exactly in line with the blade or when not paying full attention when making a cut.
Having experienced such saws I have learned much about them so when I visit a tool store I examine their stock by twisting, rocking and pulling the saw heads and the amount of movement in many new saws of popular brands is disgusting, even some pretending to be premium brands. So far only a few of the most expensive types have impressed me.
That doesn't mean the others are unusable and with care fairly accurate cuts can be made when a suitable technique has been developed - like using a rifle with bent sights...
Nov 27, 2017 | Tools & Hardware - Others
My 71/4 table saw is week can't cut blade stops
Sounds like the motor is wore out! Or maybe the belt if its belt driven
Jan 14, 2013 | Makita Saws
I am running a six inch blade width horizontal band saw in a sawmilling application, resawing flitches to thinner boards. Average depth of cut about eight inches. What blade life (swage set steel) should I...
This depends on the type of wood you are cutting. Hardwoods , like oak, will dull the blades faster and require a change after about 3 months if used daily 8x7 but you can get a longer cutting time IF the blades are carbide steel. You can add life to the saw teeth by keeping them clean and free of sap buildup too.
Specially when cutting pine.
Jul 12, 2009 | Saws
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Mitre saw won't cut square
You will have to use a regular square to check out the crafstsman and find out where it is wrong.
Jan 16, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Dewalt Mitre Saw Workstation Logo
139 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
