My nomad zen jukebox is stuck in rescue mode and still not working correctly
  • 1,029 Answers
If you can boot into the Recovery Mode menu, run the Disk Clean-Up option from there. As long as your drive isn't physically damaged, it should be able to fix your problem.
> You can try the "Clean Up" option in Rescue Mode. - let it run for a few hours, and then try to reformat. if that dosnt resolve it then you know its almost gone.
If the hard drive is mechanically damaged (as it most likely is - the drives used in the Zen Xtra are rather fragile compared with current drives),As for recovering the files from your existing drive then the only possible way to retrieve the data stored on it is to utilize a Data Recovery Service but it will cost you a lot except if still under warranty
you can only replace the hard drive Taking the Zen Xtra apart is rather easy - two screws on the back, and that's it. The Zen Xtra uses a standard laptop hard drive, so it'll be easy to locate and install a new one - just be sure the new hard drive you install has a current rating equal to or less than the current rating for your existing drive. To remove the hard drive, you'll need to pop off the front cover, remove the battery, and remove the four broad-head screws that retain the hard drive in place. Then carefully pry the top end of the hard drive out, and pull it away from the case, pulling from the top end.
When you install the new hard drive, you will need to re-install the firmware.
Posted on Sep 11, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: the rescue mode v1.13.
i found this on a site and it worked for me, hit it ******* the right side as you boot it up, its sounds funny but it worked for me and a lot of other people
Posted on Feb 28, 2010
My nomad jukebox zen xtra goes into Rescue mode (v1.13) where do i get thr firmware??
http://www.microsoft.com/windows/windowsmedia/player/11/readme.aspx#IssuesupdatingfirmwareonCreativeportabledevices
See this link.
Try unistalling Windows Media Player 11 from PC. and then upgrade ur device.
Follow necessary steps.
Mar 17, 2010 | Creative Labs Nomad Jukebox Zen Xtra MP3...
The rescue mode v1.13.
I would suggest that you go to this website and do firmware update:
http://www.creative.com/products/mp3/ww
Sep 24, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Trying to recover nomad jukebox zen extra
Get an original Vista operating system disc..
then insert d CD and boot from the CD!
Apr 29, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen nomad jukebox xtra in need of repair, any suggestions?
Look up "jazzmantim" or "Jazzman Tim" on google or ebay; he specializes in fixing and upgrading Zen's, and is competent and fair.
Mar 07, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Mad at my nomad
It appears that my Creative Nomad Jukebox is stuck in the Rescue mode. It displays the four options suchn as. 1.Clean up 2. Format all 3. REload OS 4. Reboot
It is not recognised on the computer either.
Steve
Dec 12, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Nomad Jukebox Zen Xtra Display Failure
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 25, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomand Jukebox Zen Xtra
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
Oct 31, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
87 people viewed this question
 Grubhead
Grubhead
