Question about Penn Gt Series Levelwind Reels 330GTi
How do I take apart the crank side of a Penn 209? I can't get the star drag wheel off.
The star drag wheel unscrewed, just had to us a little force.
Posted on Sep 12, 2009
Old Penn 209 level wind not turning but spool works is there a part missing ??
There are many small parts within the reel itself and something may have gotten dislodged or someone may have taken it apart and not put it back together properly. There are exploded parts diagrams available at www.pennreels.com to assist you, but they can be very difficult to read. If you take your reel apart, be VERY VERY careful not to lose anything, especially a very small spring that holds the ratchet lock (dog) in place.
Aug 02, 2010 | Sport & Outdoor - Others
2006 Pacifica emergency brake problem.
The only manual adjustment for the parking brake on these is at the shoes themselves. Procedure for that is as follows:
1) Place parking brake lever in "full released" position.
2) Raise and support vehicle.
3) Remove plug in parking brake shoe support to access adjuster star-wheel.
NOTE: Through the access hole, rotate the adjuster wheel in the following direction to expand the shoes outward against the drum.
Left brake--Rotate star wheel toward rear of vehicle.
Right brake--Rotate star wheel toward front of vehicle.
4)Using an appropriate tool, turn adjuster star wheel until wheel will not rotate (dead lock).
5) Back off adjuster six detents (teeth).
6) Rotate wheel, checking for light drag. If drag is too heavy, continue to back of adjuster one detent at a time until light drag is present. Do not back off star-wheel more than 17 detents from wheel lock.
7) Install access plug.
8) Adjust opposite wheel parking brake shoes using same method.
9) Lower Vehicle.
10) Apply and release parking brake lever once to ensure proper operation of parking brakes.
These directions are directly from 2006 Pacifica factory service manual. If you have any other problems feel free to ask. v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Mar 07, 2010 | 2006 Chrysler Pacifica
I have a Penn 650 SS spinning reel Ihave loss the drag I have tighten it as hard as I can and it still has no drag
If the knob is not stripped, replace the drag washers under the drag knob.
Replace key #'s 6 and 56T with 3x 6-155 carbon drag washers, available here: http://www.mikesreelrepair.com/product_info.php?products_id=7806
this will bring your drag back to better than new condition!
Here's a schematic: http://www.mikesreelrepair.com/schematics/displayimage.php?pos=-4123
Best of luck!
Mike
Nov 12, 2009 | Penn Gt Series Levelwind Reels 330GTi
The Drag on my 750ss does not work what could be the problem?
This happens after you screw the drag too tight so that the plastic washer under the spool is pressed out. The fix is simple: cut excess of that washer and tighten properly.
May 30, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
My Penn 114H cant't tighten drag,only to 12 lbs ,when I tighten the I can pull the line at 12 lbs
http://www.pennreels.com/
Call customer service.
Your drag is either worn or it is assembled improperly.
When I need parts or service, I call penn directly. They are the best reels out there as far as I'm concerned. And most of them are made in USA and backed by Penn.
It is the only reel that I care to fish with
Apr 21, 2009 | Penn Gt Series Levelwind Reels 330GTi
Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Apr 15, 2009 | Penn Gt Series Levelwind Reels 330GTi
Penn 113 senator
If ythere is a screw directly across from the crank, remove the screw and insert the crank from that side
Feb 10, 2009 | Penn Gt Series Levelwind Reels 330GTi
Penn Gt Series Levelwind Reels 330GTi Logo
448 people viewed this question
Top Penn Sport & Outdoor - Others Experts
Mike Marcotte
Mike Marcotte
raysaw
Tom Chichester
Are you a Penn Sport and Outdoor - Other Expert? Answer questions, earn points and help others
