Question about T-Mobile Computers & Internet
Ss20whi/xeufreezer defrosts then refreezes temp gauge always reads -20. already replaced temp sensor but just the same,the wire on the new sensor was a lot longer so i had to coil it inside the cover what do i try next?
    President:
  • 1,884 Answers
The temp guage may be faulty if you have replaced the sensor and the prob still persists.
Posted on Sep 19, 2009
2.2L Chevy Cavalier- temp gauge always redline, fan kicks on as soon as car starts but the car is not overheating. Temp sensor? Temp sending unit? Something else? Help!
check the that wire to the temp sender unit is not shorting out as it will read hot if it is remove the wire and if the gauge goes back to cold then replace the sender unit.
Jan 05, 2014 | Cars & Trucks
Temp gauge is not working
Find the wire to the temp gauge sensor on the block of the engine. Unplug the wire and check your gauge. It should read max hot or cold. Ground the wire to the block and check your gauge. It should read the oppisite of the test before. If it does this then replace the temp sender. Otherwise head up the wiring to the gauge. Rare.
Greg
(most engines)
Jan 18, 2013 | 2000 Ford Contour
1990 gmc K1500 5.7L, temp. gauge not working:
To review, you have two temp sensors, one for the gauge on the dash and one for the computer. If you unplug the sensor for the computer the reading will be minus 30 degrees or over 300 which will make it very hard to start. Unplugging the sensor for the gauge would have no effect on the computer.
According to the wiring diagram, the wire for the temp gauge is green, and the wires for the temp sensor for the computer are yellow and black.
Aug 24, 2012 | 1990 GMC Sierra
Temp gauge stuck
Maybe temp sensor became disconnected, or damaged.
Look for it in the engine block, right by the radiator hose intake. Test the gauge by shorting the wires that lead up to sensor. If gauge reads full temp, gauge and wiring is ok. Next clean the contacts at the sensor, and if not successful, replace the sensor.
Feb 03, 2010 | 2004 Hyundai Elantra
Freezer thaws then refreezes
I was going to suggest that maybe it is a self defrost issue not shutting off when it should but sine you mentioned this knob, it suggests a thermostat out of calibration - I can rule out circuit problems since you can manually turn on compressor by turning the knob to a cooler position - you will need to have it serviced and change the thermostat which is not cycling whne it's supposed to.
ALSO - do not refreeze foods in your freezer that have thawed ! Throw them away !!! Normal freezer temps should not be warmer than 10F, the normal temps are 0F, and optimal recommended temp -10F (for hard ice cream) and to allow better recovery in case of power failures.
Refrigerator section no warmer tan 40F.....optimal recommended 34F.
Oct 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Outside temperature gauge for my malfunctions
The problem is a bad ambient air temp sensor or a broken wire to that sensor. The sensor usually is located in the front of the engine bay on the support for hood latch, between the outer grill and the radiator/condensor assemblies.
Jul 22, 2009 | 1997 Buick Riviera
93 jeep wrangler 6 cyl. my temp gauge never shows full temp. only goes to about 130 degrees. I have a 195 oem thermostat but still gauge does not climb above 130,...bad gauge, wiring???
Assuming the t-stat is good, I'd look at the wiring next. Make sure the connector is clipped onto the water temp sensor/back of the gauge and that the wiring is not chaffed, etc. If that all looks good, replace the coolant temp sensor...they're $20 or so. If it still does it, the gauge is bad.
Apr 15, 2009 | Jeep Wrangler Cars & Trucks
Temp gauge or thermostat light is flashing
This sounds like perhaps the coolant level sensor in the coolant reservoir is stuck or faulty... OR the wiring to the sensor is grounding out (shorting)... Hope this helps...;-)
Apr 09, 2009 | 1997 Volkswagen Cabrio
Temp gauge stay on cold.
Switch ig. on, ground the sender unit wire for about 3 seconds see if the temp. gauge moves, if so change sender unit, if not then it is a faulty gauge reader.
Jan 15, 2009 | 2001 Chevrolet Impala
2001 Jeep Grand Cherokee Engine temg gauge not working
If you changed the coolant temperature sensor and it had a 5 volt ref signal to it then you replaced the wrong part. You need to replace the coolant temperature sending unit.  The coolant temp "sensor" is an input to the ECM for your fuel injection system. The coolant temp "sending unit" is for coolant temp reading at the gauge, It is an NTC switch (negative temperature coefficient) which means as temp increases/resistance decreases.
Dec 19, 2008 | 2001 Jeep Grand Cherokee
Computers & Internet Logo
19 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
