Question about Motorola Mobility TracFone C139-4 Cellular Phone
It it normal for the phone to beep loudly while its charghing? just replaced battery. water damage indicator is red but phone functions. new battery but still dosent seem to hold charge. what is beeping and how can it be stopped?
I have the HTC One and the battery takes forver to charge up and the battery is also very quick to drain down when I use apps is this normal?
You battery is most likely damaged/defective, maybe water damage to the battery check the edges of the battery there should be a tiny white sticker with red X's on it if the sticker is all red then it has water damage. But could just be bad battery I'd buy a new one.
Nov 19, 2013 | HTC One X Android Smartphone Glamour Gray
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
Jul 20, 2011 | Vtech VT 2461 Cordless Phone
I have an impact 7000 can I get new battery The phone started cuttin out dropping calls ATT store said battery indicator showed some water damage Waiting for IPhone in Sept so would just like a quick...
unfortunately replacing the battery wont solve the problem.
the battery is where the external water damage indicator is but its actually the phone that would be damaged, and even worse, water damage is almost never repairable at a close to reasonable cost.
Your best bet would be to look up a used phone on a local classified website and get something to tide you over til the new iphone.
reference: 4 years of working for a canadian telephone company, 6 months of which working as a technician.
Jun 13, 2011 | Pantech P7000 Impact Crystal Hard Case
Two nights ago, there was a major power surge in my area and lots of appliances were knocked out. The alarm box AC transformer burnt out. I replaced it but the alarm system, every half hour or so keeps...
It's possible the power surge damaged the panel as well. Disconnect the battery and wait for the AC Loss. You'll get a Low Battery on the keypad. Enter your code + off to silence the beeping. If the panel is damaged, it will shut off and back on when you would normally get the AC Loss. Good Luck.
Apr 14, 2011 | Honeywell Ademco Vista 20p And 6150 Keypad...
Bought a new samsung wave 3 weeks ago went to charge it would not switch on again left battery out for 1full day it then powered up used it for another day or 2 went to charge it same problem.went back to...
Check the water damage indicators on the phone and battery. They are white stickers, and they will turn red if they have gotten damp or wet. Be aware that some phones can get water damaged from condensation, or being in a moist environment like a bathroom.
If the damage indicators are clear, they cannot prove that it has damage and you should take it back and talk to someone else.
Mar 02, 2011 | Samsung Cell Phones
My baby put my N96 in her mouth and it stopped working,what do l do
Not sure who your service provider is ... try doing a hard reset. Pull out the battery and the sim card if it has one while the phone is still on. While you have the battery out check the warranty sticker there should be one on the phone under the battery and one on the battery itself. It should be white with maybe some red X's. If it is all red you have water damage. Also take the battery and look at it from it's side to see if you notice and raising or bubbles on it; another indication of water damage. The battery should be 100% flat and even. If the answer is yes then replacing the battery may fix the problem but you will more than likely need a new phone.
Mar 01, 2010 | Nokia N96 Cell Phone
I have a sidekick lx 09 and i need to know if it has water damage
remove battery at the back and check for the LDI (liquid damage indicator) is red or white. The LDI will normally be a small label on side at the back of the phone. A red lable will reconfirm that your phone has been liquid damaged. Or you can either go to a store or contact your service provider for them to walk you through it.
Aug 11, 2009 | T-Mobile Danger Sidekick Vehicle Power...
Verizon Voyager will not chage or work on battery, fine on AC
Sounds like the battery connections may be corroded, try gently cleaning them with a pencil eraser. Clean the connections on the battery and in the phone. Water damage is indicated by a red indicator in the phone. if it is red it indicates water damage which is probably why they will not replace it. If you have insurance on the phone that may be an option for you.
Apr 21, 2009 | LG VOYAGER VX10000 Cellular Phone
I have dropped the phone in the water and now lost all functions on the key board
Unfortunately, water is very damaging to a phone, and often voids your warranty for getting it fixed. There's even an indicator in some phones that turns from white to red when it gets wet to tell a manufacturer that the phone has been submerged in water.
Technically, you'll need to buy a new phone, unless your carrier is feeling especially nice in which case they may just give you a new one, or they may give you a new one if you can convince them the water moisture indicator is white and not red ;)
Aug 11, 2008 | Samsung Cell Phones
Problem
oooh doesnt sound too good! but my phone got a bit wet and stuffed up quite a bit so last night im my room on the shelf, i took out my sim card, battery, back cover and left it open to get some fresh air. and now it works fine:) goodluck you might want to try that but yours was alot wetter than mine!
Nov 23, 2006 | Motorola Mobility V265
Motorola Mobility TracFone C139-4 Cellular Phone Logo
77 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
