Question about Radio Shack 250 Watt PA Amplifier Amplifier
I have a optimus XL-260. i had i all wired an working great. a friend of mine said he thought it should put out more power to my 10 inch kicker. so i let him Bridge it. i NEVER SAW IT DONE THIS WAY HE HOOKED THE SPEAKER UP BRIDGED FROM CHANNEL 1 TO CHANNEL 4. THEN HE TOOK A INDIVIDUAL WIRE AND HOOKED IT NEG TO NEG ON THE SAME TWO CAHNNELS HE USED TO BRIDGE THE KICKER. IMMIDITIATLY MY AMP WENT NTO PROTECT MODE. THEN IT WENT OFF. THE NEXT DAY THE RED PROTECT LIGHT COMES ON 2 SECONDS AFTER IT TURNS ON? WEIRD I CHECKED ALL CONNECTIONS THEY WERE OK. IT EVEN HAPPENS W/NO SPEAKERS CONECTED TO IT! WHY?
2 Suggested Answers
SOURCE: Ballpark
You extend wire from speaker what ever you want distance.
Posted on May 26, 2008
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
How do you install a 10 inch kicker with a built in amp
Rum a fused power line to the Battery, a fused remove on from the head unit or keyed fuse in the fuse box, ground it to the chassis, hook up the signal source using speaker wires or pre-amp cables. Bolt it down so it wont more while driving
Dec 28, 2013 | Kicker Car Audio & Video
Kicker KX500.2 amp cuts out for no reason
  • yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 23, 2010 | Kicker KX500.2 Car Audio Amplifier
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Kac-8152d powers on, but no power output to subs
Well, the sad thing is, it can be a number of things. You will have to do a process of elimination. Try replacing the amp first, borrow one off a friend. Second try replacing the subs. If those don't work, read the manual to your deck. Find the audio settings, and check to see if the sub section is "on".
Jan 29, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Kickers dont beat like they should
try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Problems turning on
Pull your lead power wire right off the positive term. on your battery
Dec 31, 2008 | Kicker IX404 Car Audio Amplifier
Wiring
provided that the memphis studio series is still 1 ohm stable you would wire each coil of each speaker like this : posive to positive negative to negetive on the speaker using 2 jumper wires then run 1 coil from each subs positive and negative the input on the amp that amp would see a 1 ohm load from both speakers as each speaker would become a 2 ohm load. from experience, memphis does not make an amplifier that is brutal enough on power for L7 15" solos, i have the st 1600 d amp running only 2 dual 4 ohm 10 L5's and it is barely enough power for them. For less money than your 2 subs cost retail I can get you brand new matching 2000 watt true competition rated and proven 1 ohm power and 2 subs that would physically fit in your current box, i would however recommend a very very large box for 2 15" squares. you can email me at sicaudio@msn.com , my advice and system designs are always free even if you do not buy thru me. I am usually 1/3 to 1/2 what retail is with full warranties and i can drop ship anywhere in the U.S.A.
Jun 25, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 4_2ohm_dvc_1ohm.gif
Dec 17, 2007 | Kicker CVR12 Car Subwoofer
Radio Shack 250 Watt PA Amplifier Amplifier Logo
136 people viewed this question
Top Radio Shack Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
k24674
Are you a Radio Shack Audio Player and Recorder Expert? Answer questions, earn points and help others
