Question about Hotpoint Aquarius WF000 Front Load Washer
The conditioner drawer is not working - Hotpoint Aquarius WF000 Front Load Washer
    President:
  • 1,653 Answers
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Posted on Sep 11, 2009
Testimonial: "really helpful and quick with your response as well."
    Sergeant:
    Champion:
  • 205 Answers
Mam check for the water flow at the time of conditioning if water is flowing good with pressure then the conditioner will be drawn easily and if the water flow is less and if there is no water flow you should check the water line of the conditioner and check the valve provided to the conditioner line this should operate at the time of conditioning.if its not operating you should change the valve.
Hi. the drawer into which the fabric conditioner is poured, is not being flushed, i.e conditioner remains in drawer. Any idea how I unblock the water inlet ? Thanks
usually the drawer has a plastic tube with cap in it.remove the small cap and clean/wash with water until the residues of the previous conditioner is cleared. then put back the small plastic cap. hopefully it will drain properly on your next use of conditioner
Sep 03, 2015 | Washing Machines
The fabric conditioner drawer is not dispensing the conditioner in my Miele WT945S washing machine. I have taken the drawer out, clean it thoroughly and also the interior of the machine (where the drawer...
The fabric conditioner drawer is not dispensing the conditioner This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 12, 2011 | Washing Machines
Zwf 1221 w fabric conditioner wont go through machine
Sometimes the little drawer for the conditioner can get clogged with soap residue take out drawer by pressing on release tab in drawer,take to sink pull out plate above syphon holes make sure all holes are clean also under small plate clean out recess.The other check is make sure you have good water pressure and clean the little holes above drawer with an old toothbrush and a bent piece of wire.There may be a solenoid not working all these need looking at.Hope This has been helpful.
Good Luck
May 05, 2010 | Zanussi Washing Machines
Fabric softener drawer filling with water
lift out the blue part of the conditioner compartment and you'll see attached a tube at the end.
clean this out completely.
also check the tube in the compartment is clear.
poke a cotton bud down it to clear it.
if you want to check to see if its worked take the drawer out(blue button at back of drawer) put the blue grid back in the dispenser and fill the compartment up under the tap ,hold the drawer level.
as it gets full you should see water start to flow out the back ,turn the tap off and if its worked the compartment will slowly empty.
these were a big problem for hotpoint and concentrated conditioners will block it regularly.
Jan 17, 2010 | Samsung Washing Machines
My Washing Machine is emptying the Fabric conditioner too early
Washing Machine has started to empty the Fabric Conditioner high water or blokage in draw
Aug 05, 2009 | Washing Machines
Fabric conditioner drawer not emptying
fabric conditioner drawer This video will show you how to keep your soap draw clear and how to service the parts
Jul 28, 2009 | Washing Machines
Fabric condtioner won't go through into drum during rinse cycle
May 25, 2009 | Candy AQ130 Front Load Washer
FABRIC CONDITIONER STILL LEFT IN DRAWER
water pressure or This video will show you how to keep your soap draw clear and how to service the parts
Aug 24, 2007 | Zanussi FS1155W Front Load Washer
Conditioner is not used in the wash cycle
I had the same problem with my Bosch Classixx 1200 Express.
It was fixed today & I now know what to do in the future if it happens. The water gets into the soap/ conditioner dispenser drawer via 2 pipes. One points to the main detergent compartment and the other to the pre-wash and conditioner compartments. The pipes become clogged with a type of mould. This meant that in my machine the water was bypassing the conditioner. I had already removed the drawer and cleaned it up and cleaned the jets above with an old tootbrush but it hadn't solved the problem. The repair guy used a cable tie (one of those that is quite firm & will lock) and pushed it up inside the bigger jets. This loosened the black gunge. Then ran water thru from start of the basic cycles and all is now OK
Dec 12, 2006 | Bosch Classixx WFC 2465 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
152 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
