Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Control panel above water dispensor malfunctioning
We changed the board on the back and the control panel on the front problem still continued. the tech said that a blue wire in door between control panel and fridge was not responding something about oms or short in navy blue wire so he said we had to replace the door but how can I be sure when they misdiagnosed the problem three times prior. PLEASE HELP!!!
  • 8 more comments
  • nonna554 Sep 11, 2009
    kenmore elite model # 795 751 93401 rev # not known maybe 75193 serial #504KR00200 the problem first began when the front control panel lights would lock up specifically button that says express freeze. the button lights were on but were unresponsive when touched. we unplugged the fridge then replugged it back in and that seemed to help with freezing but then it continued so we were told to change board on the back of fridge. did that but problem continued. the problem changed because now the front lights on control panel were going out completely. no lights no response to touch of buttons. if i unplugged the fridge and replugged it in the lights come on and buttons are responsive(make noise and numbers change) for about 10 - 15 seconds before lights out and no response. we called tech to come to house and his diagnosis was to change board on back and control panel on front. he did that and problem continued. he proceeded to check wires (yellow, red, light blue, dark blue, orange and black. From rear panel to the top of fridge they were all responding well from top of door to front control panel the dark blue wire was not responding the tech mentioned short in wire and something about ohms. can u help I hope this was info you were asking for.
    The tech's recommendation was to change the door but I have doubts can you help
    Sep 11, 2009
    - kenmore elite model # 795 751 93401 rev # not known maybe 75193 serial #504KR00200 the problem first began when the front control panel lights would lock up specifically button that says express freeze. the button lights were on but were unresponsive when touched. we unplugged the fridge then replugged it back in and that seemed to help with freezing but then it continued so we were told to change board on the back of fridge. did that but problem continued. the problem changed because now the front lights on control panel were going out completely. no lights no response to touch of buttons. if i unplugged the fridge and replugged it in the lights come on and buttons are responsive(make noise and numbers change) for about 10 - 15 seconds before lights out and no response. we called tech to come to house and his diagnosis was to change board on back and control panel on front. he did that and problem continued. he proceeded to check wires (yellow, red, light blue, dark blue, orange and black. From rear panel to the top of fridge they were all responding well from top of door to front control panel the dark blue wire was not responding the tech mentioned short in wire and something about ohms. can u help I hope this was info you were asking for.
    Sep 11, 2009
    - The tech's recommendation was to change the door but I have doubts can you help
    04/2005
    just discovered that the dark blue wire is broken and need some advice
  • beamerguy740
    beamerguy740 May 11, 2010
    Would help to have a model # and manufacture date.
  • James Hilton
    James Hilton May 11, 2010
    I can't see your first problem you had. Respond back with you initial problem and what has happened from there. I'll be glade to help but I'll need to know what the situation was and is now. When you respond back, be sure to include your complete model number, Rev. number and serial number. Respond and let me know.
  • anantha reddy
    anantha reddy May 11, 2010
    sir please tell me what was the problem you were facing
  • dprats2 Jul 13, 2010
    I have the same symptoms on mine. What was the solution??
    What was the problem? I have same exact symptoms and would like to know where the 'short' was, if that was the problem. Did the door work?
    Sergeant:
    Champion:
  • 205 Answers
Hello mam thanks for your information. now tell the tech to check all the circuits of the refrigerator and the freeser and also he should check the compressor,and if he finds any short circuit or loose connection he will rectify it this was to done before changing the panal ok dont worry tell him to do it now.
Posted on Sep 13, 2009
Frigidaire GLTF2940ES0 front load washer. turn it on and the water fills for 1-2 sec then turns off. replaced pressure switch and control panel. still does the same thing. someone mentioned the door...
does it ever agitate ... if it does than the door is locked ...there is a magnet that falls off these machines the detergent dispensor that tell the washer control board that the detergent dispensor is closed so water wont spray out if left open ,,,,magnet rectangle and size of a pencil rectangle shape .... you can try putting a large size magnet on the opening of dispesor shroud ,,,, usually when you replace the control board they have removed the magnetic dispensor reed switch and just jumped across the board eleminating this connection.
Jan 31, 2011 | Frigidaire Washing Machines
Tip
Appliance Repair Boise - Maytag Refrigerator Lights Blinking, making Clicking...
If your Maytag Refrigerator has the above symptoms, you may also see the dispensor ice door opening and closing, then your control board is likely bad. The control board is located on the back of refrigerator under a panel. Be sure to follow the instructions that come with the new mother board. There may be some re-programming that is necessary.
Rich
on Oct 12, 2010 | Refrigerators
Ice and Water Dispenser on door stopped working
Sounds like the dispensor board has lost communication with the main control board . The part number for the main board is WR55X10942 . This is the board behind the refrig , behind the small 8 X 10 panel . It runs about $ 150.00 . I have never found a bad dispensor board . The main board is easily replaceable .
May 26, 2010 | GE GSS25LGM Side by Side Refrigerator
I can't get either water or ice. The light flashes once and then goes out. It was working off and on, but now has completely quit.
It sounds like a main control board problem . Not the one in front , but the one behind the refrig , behind an 8 " X 10 " small panel . The part number is WR55X10656 .
Since you mentioned that it " worked on and off " , this means that the dispensor board is not communicating with the main control board . I have yet , to find a bad dispensor board . Always ends up being the main control board .
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE GSS25QSTSS no lights working on the water and ice dispenser. No light working, no ice dispenses or water. Tried unpluggin no luck
I would remove the bottom kick panel ( 1 screw on each side ) and follow the wires to the receptical ( about 5 inches from bottom of door ) . Wiggle the receptical , to see if any of the dispensor lights come on . Also try pushing the wires into the receptical farther . If still no lights , then the main control board behind the refrig ( behind 8" X 10 " panel ) is probably bad . No communication between the main board and dispensor board . Part number WR55X10942 . I have yet to come across a bad dispensor board , so , replace the main board first . If the receptical process doesn't work .
Sep 18, 2009 | GE GSS25QSTSS Stainless Steel
Water dispensor problem (zIss420dmass)
hmm, wonder if the flap is broken inside where the water comes out or the control board is not working properly
Jun 23, 2009 | GE Refrigerators
GE Fridge #GSS25LGMBWW water and ice control panel not working
Your dispensor board , has lost communication to the main control board . You will need to replace the board , which is located behind the refrig , behind the 8 " X 10 " , small panel . The pt # is WR55X10942 . You do NOT need to replace the board on the dispensor . The board behind the refrig , is , easily replaceable .
Apr 01, 2009 | GE GSS25LGM Side by Side Refrigerator
Removing water despenser on Kenmore 79575196401 fridge
this is an LG made machine, ther eis no simple way off, youll need to pry it off form the edges, no screws hold it, merely plastic tabs and pressure. I hate this dispensor for this reason , but the dozen or so i removed, i havent broken any yet. pry slowly and youll get it
Jan 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No power to the water dispensor or other buttons on the door
it has to be one of many things the Control Board or Double Outlet Water Valve,Dispenser Door Solenoid
Here to help
Shaun
Nov 16, 2008 | GE GSS25JEMWW Side by Side
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
117 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
