Question about Refrigerators
Refrig warm inside, light works & fan comes on. frig is 4 yrs old
  • beamerguy740
    beamerguy740 May 11, 2010
    Model # and Manufacture Date? Possible Defrost Timer Bad. When in Defrost mode Compressor won't run, so won't cool.
  • 93 Answers
Is your compressor running? Remove the back lowr panel and see if it is running. Put your hand on it and see if it is vibrating. If not then either you have a bad compressor, or the compressor start relay is bad. It also could have leaked the refrigerant if the compressor is running.
Posted on Sep 12, 2009
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Inside lights not working on frig side, working on freezer side, changed all 3 bulubs
You have a bad control board , located behind the refrig , mounted to the bottom left corner , inside the white plastic box . Also , the temp adjustment light , should be out . This board , is held onto the refrig , by those 2 , 1/4 " screws . It is easily replaceable , and costs about $80.00 .
Dec 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigator not staying cold also the back of refrigerator getting very warm and fan not moving enough hot air out. in a slide. the temperature inside the refrigerator is not staying between 38-42 and the...
are the coils clean under the frig or some models have in the rear clean and now if clean and fan doing its job then possible a sealed system issue and you'll need to get a knowledgeable person to check for weak charge or leak
Aug 20, 2009 | Refrigerators
My GE refrig is side-by-side & 15 yrs. Freezer is good, refrig is not cooling good. its 55C instead of 35C on the coolest setting
Check the evap fan inside the panel in the freezer. Try giving it a spin and a drop of oil. Replacement fan runs about $95
Aug 11, 2009 | GE Refrigerators
GE GSS25KGSA.... the freezer is no longer freezing regardless of temperature setting. It gets cold but no freezing. There used to be more noise during cycles, but that has stopped also.
The fan that circulates air in the freezer compartment is frozen & not circulating air - resulting in a freezer compartment that is cool but not cold. The reason is that the “heater & bracket” that warms & defrosts the evaporator coil & the fan above it has died & w/no defrosting, the coil & the fan load up with frost & ice & stop working.
Temporary Solution:
1) Unplug the frig.
2) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
3) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes. (if you leave them in the freezer, they will melt & refreeze & make a disaster).
4) There is a metal panel below the lights & it should have frost & ice built on it.
5) Get two (not one) hair driers, set them on high heat & melt all the frost & ice & keep on melting & defrosting for about 10 minutes.
4) Plug the frig back in.
5) The freezer fan should be turning.
6) Put the shelf & food back in & close the door.
7) Expect this problem to reoccur in one to four months...
Solution:
1) Get a “heater & bracket” GE part number WR51X10055, about $30 w/shipping on eBay. This is for a GSS25KGSA GE side by side (the last two letters WW, BB, & CC are colors). If you have a different GE side by side, the correct part number can easily be found at www.searspartsdirect.com. Nice drawings.
2) Unplug the frig.
3) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
4) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes.
5) Take out the light cover. One Philips screw on top & two press-to-release plastic things on the bottom.
6) Unscrew the light bulbs.
7) Take out the metal panel below the lights. Four ¼” screws. It is held in by two tabs at the top, so swing the bottom out & pull it down. Be careful not to bend it.
8) Get two (not one) hair driers, set them on high hot & melt all the frost & ice on the evaporator coil. Do NOT touch it.
9) Remove the “Heater & Bracket” by unscrewing the two Phillips screws and then unplugging the red & blue wires.
10) Install the new “Heater & Bracket” by plugging in the red & blue wires & replacing the two screws. Be careful not to get it backwards when plugging the wires; only goes one way.
11) Put the back panel back in & secure it with the 4 ¼” screws.
12) Reinstall the lights & cover.
13) Plug the frig back in.
14) Put the shelves & food back in & close the door.
15) Expect this problem to reoccur every 3-4 years; great designs fail after the warranty is up, and keep the repairmen & parts people employed …
p.s. about once a year, you should vacuum all the accumulated dust off the condenser coils. They are hidden behind a metal cover at the bottom back of the refrig. If you don't, expect the dust eventually block all airflow & the compressor will burn up & you will be buying a new frig.
Generic GE Side by Side Refrigerators GSS25KGSA, GSS25KGSAWW, GSS25KGSABB, GSS25KGSACC.
Jul 08, 2009 | GE Refrigerators
I have an amana side by side refrig, the frig side cools a little
sounds like yhour compressor is not runnning, look behind the unit and se of the fan down below is turning and if the compressor is cold, or overheated and redhot
Mar 09, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
FRIGE AND FREEZER ARE WARM NOT WORKING
Make sure you hold the door switch closed too check if the evaporator fan is working also check if the evaporator coils are froeen up..
Sep 15, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
