Question about HP Deskjet 6980 InkJet Photo Printer
The printer has power and resume lights blinking, and the car does not cross everythink trace. what can i do? thanks
Power light is on & resume light is blinking, in hp officejet K850. Could anyone suggest me a solution for?
The Power light is on and the Resume light blinks. The printer is out of paper. &#... the printer, and press (Resume button). The Power light and the Resume light are on. A cover is not closed completely. ?... completely. ?
Jun 29, 2011 | HP Officejet Pro K850 InkJet Printer
Tip
How to reset Canon BJC-5000 printer?
1: Power off printer 2: Press and hold RESUME then press POWER, The indicator will start blinking.
3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode
5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN.
6: Press Power to set data.
This will help.Thanks.
on Mar 10, 2010 | Office Equipment & Supplies
Tip
How to reset Canon S9000 printer ?
the procedure is as follows:--
  1. Turn off printer
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your printer should respond as normal. This will help.
thanks
Hi, The orange light in my canon ip1600 printer is blinking 5 times and green light once alternatively. Please give me a solution to fix it. What is the reason behind this problem? Thanks.
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Jun 25, 2011 | Office Equipment & Supplies
Hi i have a problem here IP 1300 canon printer it says that i don't install cartridge properly but i try to reset it and still desame..the orange light still blinking and also the green light please help...
fallow this procedure it will help.
  1. Turn off Canon Pixma iP1300 Printers
  7. Press the Power button and the Canon Pixma iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1300 Printers should respond as normal
Apr 20, 2011 | Canon PIXMA iP1300 Printer
Howdo you fix an error message 5C00 on a Canon iP90 printer.
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Please rate this solution, thanks!
Mar 07, 2011 | Canon Office Equipment & Supplies
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    Will not reset, light blinks 8 times
    Hi there you can try this
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. Release RESUME
    3. Press RESUME twice, then release POWER
    4. Let green light blink until printer is done futzing
    Select function with RESUME press POWER to execute:
    presses - light color - function
    Number of presses - light color - function
    0 presses - green - Test print (or exit service mode on i960)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    All The Best Pineworks
    Jun 04, 2009 | Canon I990 InkJet Photo Printer
    Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
    Canon i850, i950, S600
    2. release RESUME
    3. press RESUME twice, then release POWER
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
    If I could be of furtheme know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    May 01, 2009 | Cannon Canon i960 Photo Printer
    I need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
    Try resetting the printer:
    Jun 20, 2008 | Canon PIXMA iP90 InkJet Printer
    HP Deskjet 6980 InkJet Photo Printer Logo
    158 people viewed this question
    Seeker5211
    Seeker5211
