Question about TruTech PLV16190 Television
The TV will change the function/channel on its own. It may continue to change the function/channel. If you hit the volume or function key the TV will sometimes stop. Sometimes when you change the volumn [remote or on TV] the function/channel will change. Do you know what is wrong? Is it the main board the tuner board or some other problem?
  • 1,029 Answers
Check to see if any of the front panel buttons is depressed or stuck??? this could lead to continuos changing channels.this is a bad button assembly and is common on your model. in most cases you can just unhook it and then the remote should work the tv just fine.if the button is okay then you known that the remote sensor is bad and need to be repaired.hope this helps thanks and Godbless
Posted on Sep 11, 2009
AUTOMATICALLY CHANNEL / VOLUME AND MODE CHANGING
please check touch key board i think it is defect
thanks lal electronics
Jul 15, 2013 | Insignia 32" 720p Flat-Panel LCD HDTV
Unable to set up remote URC 22935
MENU • Set Up • Searching For Yor Code • Blinking Back the Code:
Redefining a Key • Punch Through • Volume Default • Clearing Out
Key mover • Favorite Channel Scan • Macro-Sequence
How to Program your One For All remote
(Models URC-2005, URC-2099, URC-4005, URC-4050, URC-6050)
Set Up
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
PRESS and HOLD the MAGIC button until the red LED flashes twice, then RELEASE.
ENTER the 3 digit code for your brand.
You should receive 2 quick flashes after entering your code.
PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
menu
If you have tried all of the set-up codes for your brand of eqipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following proceedure to search for your code.
ENTER 9-9-1 (two blinks on the remote)
ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
When your device turns OFF, PRESS the MAGIC button and RELEASE it to lock in the code for your device.
menu
PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
PRESS 9 - 9 - 0.
PRESS 1, carefully COUNT the number of blinks. (1st digit)
PRESS 2, carefully COUNT the number of blinks. (2nd digit)
PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
menu
Redefining a Key
PRESS 9 - 9 - 2.
PRESS the DEVICE,(TV,VCR,CABLE,etc.),key you want moved
PRESS the DEVICE key you want to replace.
Example: If you want the Aux key to be a TV key:
"MAGIC" (2 blinks) 9 - 9 - 2, TV (you want to move TV)
Then AUX (you want to replace AUX).
menu
Punch Through
This sets Volume to work for one device in all modes.
For example, the TV volume will work in the cable and VCR modes.
PRESS 9 - 9 - 3.
PRESS the device key you would like the volume to come from.
You will get two blinks on the remote.
NOTE: This only sets volume in the TV,VCR,CABLE, or SAT mode.
If you want to set the volume for a device to work just one or two other devices- refer to the instructions under "KEYMOVER-From one button to another"
menu
Volume Default
Use this to get the original volume to work on each device.
PRESS 9 - 9 - 3
PRESS the VOLUME+ key, you will get two blinks.
Now The volume is set for all original devices.
menu
Clearing Out
A Device Key
PRESS 9 - 9 - 2
PRESS the device button twice. - Two blinks.
Any Button On The Remote
PRESS the button you want to clear - RELEASE
PRESS 9 - 9 - 4
PRESS the button you want to clear twice. - Two blinks.
All Key movers,Macro's, and Defaults
PRESS 9 - 8 - 0 -- Two blinks.
Scrambled Keypad
Sometimes it seems that the keypad is "scrambled". Functions like channels, volume, or numbers are not where they should be.
If your remote seems to be acting this way, try the following proceedure:
ENTER 9-7-3 (two blinks) (for URC-2005, try 9-7-4)
Try the functions on the remote
If the keypad continues to act "scrambled", you may:
Be on the wrong code for your device.
A wrong code may only operate a few functions of your equipment or they may be operating inaccurately.
Have something more serious wrong with the remote.
In either case you will have to contact us for more information.
menu
Key mover
An Advanced Function To A Button
PRESS 9 - 9 - 4.
PRESS the "MAGIC" button and then the three digit extended function.
PRESS the button you wish to use for that function - Two Blinks.
From One Button to Another
PRESS 9 - 9 - 4.
PRESS the DEVICE and the FROM button
PRESS the DEVICE and the TO button
Two Blinks
EXAMPLE: To take the volume from a TV and put it in the VCR mode,
it would be: MAGIC - 9 - 9 - 4 -TV - VOL UP - VCR- VOL UP - two blinks.
You would have to do the same process for VOL DN and MUTE.
"Shifted" Key Mover
In order to stack a second function on a key; when pressing the button you want the function on in the sequence, instead hit MAGIC and then the button you want.
To use the function: TAP the MAGIC button and release, then TAP the key you chose.
FOR EXAMPLE:VCR-MAGIC(hold 2 blinks) 9-9-4 MAGIC 2-3-4 MAGIC PLAY
If you hit the PLAY button - the VCR will PLAY, if you hit MAGIC -PLAY it will bring up a display.
menu
PRESS 9 - 9 - 6
PRESS the channel to be stored, up to 3 digits
PRESS the ENTER button
REPEAT steps 4 & 5 up to ten channels
If you do not store ten channels, you have to hold "Magic" for four seconds to close Favorite Cannel programming.
NOTE: To stop scanning, press any other button on the remote control.
menu
Macro-Sequence
This will allow you do do several functions with just the touch of ONE key.
PRESS 9 - 9 - 5
PRESS the key you want the Macro to be on
PRESS the sequence of keys you want the remote to do
PRESS "MAGIC" and wait for two blinks - RELEASE.
When you hit the key you put the macro on it will automatically start the sequence.
IMPORTANT: The Macro key will be the macro in ALL MODES so it is best to pick a key you will not need for anything else in any other mode.
menu
All Material Copyright Universal Electronics Inc.
"One For All" copyright Universal Electronics Inc.
Any questions about the products should be directed to help(at)ueic.com
Apr 03, 2013 | Televison & Video
1. the newstar universal tv remote contrlol i bought, cannot change the channel, although i can use the adding/minus the volume. 2. in as much as wanted to use also for te change of channel, i follow...
Unfortunately, universal remotes often do not work as well as the packaging says.... but all hope is not lost.
First, try ALL the programming codes listed for your brand of TV. Often, one will work. Be sure to follow the programming instructions, which usually have you trying the POWER ON/OFF button first after reprogramming.
If that fails, most universal remotes have a "scan" feature that, when you start it, will cycle through every code it has stored. During a "scan" you keep the remote pointed at the set and when the set powers off, you hit the ENTER key (or the key specified in the remote manual) to stop the scan and test the functioning of your remote (channel +/-, VOL +/-, etc.)- it takes a long time and can get frustrating, but keep trying and you should find a set of codes that will operate your TV correctly.
If you have no luck, do not give up hope completely- I would next recommend that you purchase a Philips brand universal remote- this is the brand that I have found to be most flexible.
Mar 02, 2011 | Televison & Video
"K" in pink background after part installation LCD tv from sharp
When you see the "K," hit channel down and volume down on the tv. Hit the down arrow key once. You should see some the says factory init. Use the channel up and down to select "Factory Init" and hit the right key to change to yes and hit ok. Once it turns green, unplug set for 30 seconds and plug back in.
post back here if I was too vague or if you get confused and I'll write up a more easier one.
May 28, 2010 | Televison & Video
Hello my mother's rca tv is stuck on channel 91. when i turn it on and use the channel keys on the set, they don't change the channel. i'm trying to get it on channel 3 so she can watch her cable.
Press Setup until you see AutoProgram... press Volume ... you will see the channels start to change. It will cycle to ch 62 or so, then go back and do the lower channels. as soon as it hits 3, quickly press Setup. it will stay on ch3, if not do it again. Once you get it on ch3, press setup until you see Channel Add/Del ... press Volume to add it. Press setup until screen is cleared. Ch /- should now toggle between 3(cable) and 91(a/v in)
May 17, 2010 | RCA Televison & Video
VOLUME WON'T WORK USING REMOTE, BUT CHANNELS ARE TURNING. HOW CAN THIS BE FIXED?
First hit the TV button again and try and change volume, if that doesnt work try a different code as many codes can do some functions and not otheres.
Apr 16, 2010 | Universal Remote Control Remote Control
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Konka tv code
Try "auto search" with your remote. Normally you press the TV button and the "OK/Select" button simultaneously for about 3 seconds untill the TV light burns steady. Then press "channel up" one press at a time untill the TV turns off. When it turns off, then press "power" on your remote and if the TV comes back on, test the other functions such as volume and mute. If all functions work, then press the "TV" button one more time to save the code and then you are "in business". If functions do not work, then continue to press "channel up" untill the TV shuts off a second time. Then press "power" and test all functions. Continue repeating this until you find a code that enables all desired functions. Hope this helps.
Keever
Mar 04, 2008 | Televison & Video
TruTech PLV16190 Television Logo
43 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
