Question about Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
Cleaned hair/string buildup around beater bar , put everything back in place now vacuum makes knocking noise and has that burning rubber smell.
  • Anonymous Mar 13, 2014
    will spray water and **** water up just makes loud noise and smells like its burning.
    President:
  • 1,653 Answers
This sounds like the beater belt is slipping and may be due to the fact that the beater brush is not secured correctly or there is debris / grease build up inder the belt. Try cleaning it with Methylated Spirit and repalce the belt. Do not clean the belt with this. Also do not use Surgical Spitit as it leaves an oil residue. If the belt is still a problem then replace it.
Posted on Sep 11, 2009
The beater bar is making a loud noise, and the dog hair is wrapping around the bar. Why would that be happening?
You probably have dirt or garbage wrapped around your beater bar. Loose carpet strings as well as pet hair will do this. If you see dog hair on the carpet its best to pick it up with your fingers as it will make a mess of a vac. Check your drive belt as it could be on its last legs as well causing the loud noise. Probably should be taken apart and belt replaced and a good cleaning as well. You should give a good cleaning once a year.
Nov 07, 2016 | Vacuums
Tip
Burning rubber smell from your vacuum?
Drive belt is slipping.
Remover cover from the bottom of the power head or base if upright style. Usually just 2 to 4 screws.
You will see a belt (thick rubber band) connecting the beater bar (roller with brushes) to the motor. Remove the beater bar and belt. You do not need to remove the motor. The beater bar will be held by clamps and screws. Remove the screws and clamps and lift the beater bar directly up.
Take the belt to your local vacuum dealer (note make and model) and get a replacement.
Installation is the reverse of removal.
Note: you will find a lot of hair and junk twisted around the beater bar. Take the time now to cut it all off.
Hope this helped. Please rate this if it helped you.
on Mar 07, 2010 | Vacuums
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
When I use the vacuum it smells like something burning but it does work. How do I fix this? Thank you Sharon Post
Hi ssharonxxx...
Sounds like you have hair,strings,debris caught on the beater bar and it is causing the belt to burn on the beater bar or motor.
Remove the bottom of your vacuum and clean,oil and replace the beater bar, that should solve your burning smell problem.
Please take time to rate me thumbs up
Sep 14, 2011 | LG Electronics Kompressor Pet Care Upright...
A smell like burning rubber comes out of the vents whenever it is used. It starts as soon as the vacuum is turned on. I've emptied the filter, but maybe I need a new one? I don't think the suction...
Hi sevillekathe...
The problem is that you have is that hair,strings,etc has gotten wrapped around the beater bar of the vacuum and it is trying to slow down the motor but the motor will not slow down so the smell you smell is the belt burning up because it is slippling and creating smoke and smell
You will need to remove the beater bar from the bottom of the machine and clean the hair,strings,etc from around the bearings on each end of the beater bar.
Also check your filter bag, check the hose going to the vacuum if you have one for blockages, and once you have the beater bar off check your belt condition and look for blockages going to the bag.
Aug 30, 2011 | Dirt Devil M083405 Versa Power Stick Vac...
When using my hoover wind tunnel the last few times it has emitted a burnt rubber smell so my husband checked the belt and is wasn't broken or off but now when I use the vacuum the beater bar doesn't seem...
i take it the belt was put back on !! i would say hubbi forgot the tension arm a little black striker that can go in two ways but put in back wards it will not tension the arm
Jan 03, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Smells like burning rubber when I turn on my G6 Kirby vacuum.
You must take of the plastic ends from the wood beater bar and make sure the metal axels are not wound up with hair. I did this monthly with 4daughters
Feb 15, 2010 | Kirby G4 Bagged Upright Vacuum
Need to change the belt on my kirby model 519, assuming this is the problem since the beater bar is not turning and I can smell burning rubber
The beater bar is jammed--usually from thread, string, and hair that is wound up on the bar and particularly on the bar end bearings. The bearings themselves usually require cleaning and re-oiling. The belt may be damaged sufficiently to require replacement as well. Make sure to install the new belt exactly as the old one came off. Make sure that the air passage from the bar area back into the machine is clear and passes air freely. Check the wheels for stuff wound up in the bearings. Hope this helps!
Feb 01, 2010 | Vacuums
Burning rubber smell when the vacuum is on.
it sounds like the belt may be burning like the roller bar is stuck maybe or the belt is stretched and is burning itself off
Jan 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Smells like it is burning up when I use it!
You should unplug the machine, then remove the plate that covers the beater bar. Remove all debris from the beater bar, (strings, hair, etc.) and insure the belt is in proper position. If you have run it very long out of proper position, it may require replacement. Next before you put it back together remove any debis that may have collected in the intake behind the bar. You can also lubricate the bar with machine oil or WD-40.
Mar 09, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
187 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
