Question about HP LaserJet 2420 Printer
Vertical ink smudge on left side of print - HP LaserJet 2420 Printer
  • 97 Answers
The fuser film is damaged, you can replace the film only or replace the complete fuser unit.
Posted on Sep 12, 2009
checkitright
  • 1362 Answers
SOURCE: hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Posted on Nov 08, 2007
  • 49 Answers
SOURCE: black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Posted on Oct 08, 2008
Dax_Rush
SOURCE: Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Posted on Mar 04, 2009
  • 9 Answers
SOURCE: Smudge on left side of paper
It seems like your PCU's are dirty and are picking up extra toner. Take them out and look at the green rollers, any extra finger prints or dirt on them? Clean them with a clean paper towel.
Also, check your transfer unit below the PCU's, that may need cleaning or replacing. You can pull that out after removing both PCUs, turn the little screww and look at it. That can also be cleaned with a cleaning wipe or a damp paper towel. There's a little tab that you can turn to free the rollers (they'll still be a little tight) bu then you can turn the rollers to expose more surface area.
Good luck. Be sure to rate the post if it works for you.
Posted on Apr 06, 2009
ctf1800
  • 4402 Answers
SOURCE: Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Posted on Jun 04, 2009
How do I fix HP LaserJet P1606dn printing issue? it continues to print vertical line/ smudge on the far left of the printed document. Does anyone have any suggestion regarding this issue?
The smudges on the side of the paper is most likely a piece of something rubbing against the paper just after the printer puts the ink on the paper. Inspect as much as possible the path that paper takes. Look at rollers. Anything that grab the paper. Look for ink and dust build up. As for the vertical lines. Could be several things. I you haven't used you printer for awhile the ink in the nozzle could of dried up. Most new printers have a nozzle cleaning function. Try that it a couple of times. See if that helps. If it shows any sign of change after that, it dried up ink. It's a hassle to try to get the ink flowing again. I normally just to replace the cartridges. Let me know if this helps or not.
Aug 05, 2015 | HP LaserJet Pro P1606DN Laser Printer with...
PRINTING IMAGES ON CD'S/DVD'S - SMUDGES / i865
After looking at a picture of the CD you were printing to, I see the problem. The printer is trying to print blue ink on the middle of the CD, where the hole is. The problem is, since there's a hole that ink is going through and getting onto the rollers in the printer. It's then transferring back to your media as it moves through the printer. It's C shaped because you're only printing on about half of the hole. There are two ways to fix this. Either put a round piece of tape over the hole to cover it (and thus the paper will be printed on), or change your image so it doesn't print to that part of the CD. I'd suggest the latter, as it will look neater when you're done.
Oct 01, 2007 | Office Equipment & Supplies
Smudge and missing ink
remove all image units. clean the class where the laser writes on the drum with machine no laser. so clean. smudge what color replace the that color image unit.
Apr 07, 2014 | Konica Minolta Magicolor 1600W Printer
HP 1600 prints with left side smudging
If you are ask printer paper Quality then first you check it ink label and then you check paper quality because both are depend which types of quality you are used. If one in dull then printer quality also dull. I share a print quality related link please read and follow instruction.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01691481
Thanks,
HP Printer Support
Apr 04, 2014 | HP LaserJet 1600 Printer
Vertical Ink smudge or smear
The problem is with the printer head which is normal in Laser Printers. Try cleaning the printer head with a cotton cloth and it'll resolve the problem a very large extent.
Jul 12, 2013 | Canon LASER SHOT LBP-2900 Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Printing vertical grayish black ink on the left and right side of page
replace the toner cartridge, you wont have anything "dripping" out of it as the toner inside is a powder. if it still appears replace the fuser.
Oct 22, 2008 | HP LaserJet 4250dtn Printer
Black ink smudges for color print mode only, not for grayscale
Oct 08, 2008 | Samsung CLP 300 Laser Printer
HP LaserJet 2420 Printer Logo
485 people viewed this question
Seeker5211
Seeker5211
