The thermal paper is wrapping around an upper roller. Inside the sandwiched layers is the fax. This just started happening.
    Guru:
  • 389 Answers
U must to remoove some scrues about 4 scrues? then ease remoove the roller and remoove the jumed paper down
Posted on Sep 12, 2009
HV sapphire 930 not feeding properly
When stitching together a quilt sandwich, it is recommended to use a walking foot on your machine. The walking foot moves the upper fabric in conjunction with the feed dogs. Sometimes, if the quilt sandwich is not too thick, a roller foot can also help but may not be sufficient for a quilt sandwich.
What is Walking Foot Sewing Tips for Beginners
How To Use Walking Foot
How to Use Roller Foot
You may also check the presser foot pressure on your machine. This regulates the amount of pressure the presser foot applies to the fabric and the feed dogs. If the pressure is too strong, it will tend to push the upper layers of fabric, creating a bubble look. If the pressure is too loose, there is not enough pressure for the feed dogs to physically pull entire quilt sandwich under the presser foot.
(The pressure is adjustable depending on the types of fabric and thicknesses being sewn.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Oct 01, 2016 | Sewing Machines
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
Faxes are being received as black pages, nothing readable
Long time since I used one of these, and as plain paper faxes are so cheap now I do wonder why you persist with this old technology? You can purchase an all in one printer for under £50. Pick one with a built in LCD screen and you don't even need a PC.
Getting back to your current problem, it sounds as if the paper has been inserted the wrong way around. Try taking the roll out and checking again the correct way to put in the paper. Or maybe the paper roll has been out of its plastic protection for too long causing the paper to degrade. Once it has been exposed to light it is like a film for a camera, it is no good. If this has happened you may try unrolling two or three of the outer layers and cutting them off, and then reload the paper and try again. You may be lucky and find that only the top two layers have been damaged.
Oct 01, 2010 | Sharp UX 300 Plain Paper Thermal transfer...
How does one clean a panafax uf-770 fax machine? the copies are coming out black and it comes off on your hands.
You probably have a piece of paper wrapped around the fuser roller. You will need to call a technician
Apr 13, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
The paper in my fax 575 always get jammed when receiving a fax.
Rubber rollers in the paper path probably have lost their grip; the surfaces become glazed and slip instead of transporting the sheet as they should.
Gaining access to the paper path varies in difficulty since many later units may be partly snapped together and use few screws for assembly.
If you decide to attempt this, use a hard cloth and naptha (lighter fluid) to scrub the rubber rollers; this should produce some black smears on the cloth if the rollers are glazed. Don't use alcohol since this will dry them out further. Naptha is safe for most plastics and aggressive enough to cut the glaze. While you are inside, check to make sure there are no scraps of paper complicating things.
Feb 14, 2010 | Brother FAX-575 Plain Paper Thermal
Faint print after installing new roll of paper
Is it thermal paper?
Try pulling off about 12" of paper and reprinting. Sometimes the outter layers are damaged somehow.
Is the spring on the roller bar good?
Jul 21, 2009 | VeriFone Omni 3700
Paper rolling up with the thermal film
The best thing you can do, short of launching the thing into inter-galactic travel, is to clean all of the plastic parts of the machine with an anti-static cleaner. Particularly, the roller that feeds the paper and the carbon roll. Remove all paper and carbon film and unplug the machine. Clean inside the paper housing and the feed rollers before turning it back on. It sounds like a build up of static electricity, a common problem on such thermal based fax machines. Remember, the paper has the propensity to curl because it is on a roll, so any extra help it gets will send it curling like mad. Good Luck.
Jul 20, 2009 | Panasonic KX-FP141E Plain Paper Thermal...
Ink film wrapped round roller
Hi
Unplugged and try to access inside of the printer, be extra careful because you might damge the sensors. If its hard to get the film around. have it service instead.
Hope this helps
Nov 08, 2008 | Kodak EasyShare Thermal Photo Printer
There was a paper jam, I cleared it and it will not reset. The machine won't print at all, just keeps showing paper jam.
There are flag sensors in each machine. The have to sence if the paper is moving properly through the machine. They are sometimes black in color, that flag sensor might be jammed in an up postion, or broken look at where that paper stopped and look for a flapper toggle unit that senses the paper. There also might be paper still in the machine, check the fuser unit, the hot area look to see if paper has wrapped around the upper fuser roller.
Aug 28, 2008 | Ricoh Office Equipment & Supplies
24 people viewed this question
k24674
