Question about Optoma RD65 65" Rear Projection HDTV
After lamp replacement
I replaced the lamp in tv it restarted fine picture is great. NOW when I turn off the tv it begins to start up but shuts off and the two red lights indicating lamp failure are on. If I slid out the lamp and then push it back in the tv starts up fine. I have to do this everytime I shut it off. Is there a reset? or what can I do?
  • 3 more comments
  • fatmag Dec 15, 2007
    i have same issue. Replaced lamp, but I have a feeling lamp was not bad in the first place. I get sometimes one red light by lamp, sometimes both red lights, if i re-seat the lamp, it generally works fine.
  • Anonymous Jan 25, 2008
    I have the same problem. However, My Optoma RD65 TV's OEM lamp is OSRAM 120W/1.3 E23. I got the replacement lamps OSRAM/100-120w/1.0 E23h and OSRAM 100-120w/1.3 E23h, both started the first time and would not start up subsequently thereafter. However, they would start up after re-seating the lamp assembly. My OEM lamp has no issue in start-up.
    I notice that the E23h lamps have a smaller coil (inside the lamp) while the OEM E23 lamp has a bigger coil. Perhaps this bigger coil is that Optoma TV needs to start up the lamp. Based on what I read, the replacement lamps sold on ebay are all China-made knockoffs that nay not be the exact OEM-German made OSRAM. So buyer beware!! My experience speaks for itself.
  • Anonymous Feb 29, 2008
    Exact problem. I got a replacement for just the lamp, but I think they sent me a Philips bulb.
  • Anonymous Apr 10, 2008
    My replcement bulb exhibits the same problems described. Bulb was replaced a couple of days ago and the TV now takes a couple of trys to fire up.
    Yes - I bought the bulb from EBAY and it appeared to be identical to the one that I threw away. It fired up properly the first time and start-up problems appeared the next day. I have turned off the set completely by using the swithc on the left side of the television which may explain why i have not needed to re-seat the bulb assembly.
  • Anonymous Jan 31, 2009
    Same problem!  Replaced lamp with OSRAM E-23.   TV will not restart.  However, if I remove the lamp assembly and re-install it will come on.   There appears to be a protective  circuit that is tripping.  Possibly it is static electricity.
Optoma RD50/RD65 uses E23 5Kv precharge lamp. E23h lamps from ebay are 15Kv precharge. The letter h from E23h indicates High precharge voltage, 15Kv. Check out my other post here:
Insist on E23 with 5Kv precharge or it's not going to work on Optoma RD50/RD65. I ought to know, I bought 2 lamps E23h on ebay to find out the truth.
Posted on Apr 19, 2008
I just replaced my lamp. TV seems to be working fine, but I kept on getting the message saying time to change lamp. I went to the service menu using Menu 6-1-9 Menu, and try to reset the lamp life, but it's not letting me do anything so every time i turn on my TV, I am getting that error message.
Posted on Mar 12, 2008
  • 4,402 Answers
Sounds like the plug is not making a good connection needs to be seated better.
Posted on Dec 10, 2007
Why does my DLP TV turn itself off
Try replacing that lamp door switch, this has been known to cause issues in some Samsung DLPs
Contact Samsung at 1-800-627-4368 for proper part#
Oct 21, 2014 | Samsung HLP5063WX/XAA
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Replaced bulb 1 month ago, work fine, recently picture started turning green and purple very distored then tv would shut off. Now tv will try to start you hear sound but no picture, tv will not shut off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Have you studied your manual on lamp replacement? See Here:
as well as in your manual. Sometimes the lamp must be reseated
by removing it and reinstalling it with great care making certain
the door and all the gaps are closed tight.
If the lamp replacement or reinstallation does not solve the
problem you will likely need a service tech to look at the tv
as there are few user serviceable items for Plasma sets. Most
of the repairs are done by computer connection that downloads
the error messages and interprets what went wrong.
Hope this helps.
May 24, 2010 | Samsung HLN4365W 43" Rear Projection...
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
TV turns off
Your Ballast Board could be problem Now, pull back off watch as Lamp trys to turn on if there is a Spark coming from Ballast Board Lamp is Defective, If No Spark problem is in Ballast Board.
Sep 21, 2009 | Samsung HCM5525W 55" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I hope you can help me.. I own a Samsung DLP TV model no. HL56A650C1F, 56". The problem I am having is that it just turns off by itself and attempts to restart itself continuously. I hear all of the...
I hope you can help me.. I own a Samsung DLP TV model no. HL56A650C1F, 56". The problem I am having is that it just turns off by itself and lights "stand by" and "lamp" are flashing at same time.Sometimes, when I'm trying to turn it on- it shuts off by it self.
Mar 05, 2009 | Televison & Video
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Optoma RD65 65" Rear Projection HDTV Logo
621 people viewed this question
Top Optoma Televison & Video Experts
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
