Question about Acer CP-8531 Digital Camera
It turns on but closes immediately the lense is jammed
It turns on but closes immediately the lense is stuck out and the screen is white actually the lense is jammed and i cannot use it now
    President:
  • 2,761 Answers
Two possibilities: one bad, one not so bad. If you've recently dropped the camera you've likely damaged the lens tube (housing), and the camera will require professional repair. Before you panic though, the problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem is frequently due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Posted on Sep 11, 2009
Paper jam message does not clear after paper jam has been removed
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
Jan 08, 2010 | Canon imageCLASS D480 Black and White...
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
Cyber SHot DSC-W80 lens will not close.
Your lens is jammed. Odds are it's unrepairable, but as a last ditch effort try GENTLY wiggling/twisting the lens as you attempt to power down or on.
Aug 05, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Pentax optio s6
This is exactly how my problem started. Then after repeated attempts to turn it on or off the lense actually stuck in the on position. After GENTLY forcing it in the off position, it began turning on and would immediately turn back off. After reading every problem posted that had to do with the lense I figured that the lense had somehow worked it's way of the "track or gear" that moves it in and out. I don't recommend this solution unless you figure that the cost of having it repaired proffesionally would be more than to replace the camera (I am a trial and error type of repair person). On my camera, also an S6, when the lense came forward and began to retract, I GENTLY held the lense in place for just a second. I repeated this probably four or five times until it "worked itself" back into the proper position. It does make the clicking noise while doing this which made me a bit nervous but it worked. The camera actually even seems to be focusing better which leads me to believe that possibly it hadn't been quite right for a while. AGAIN... you have to decide if the cost of proffessional repair is worth it to you. I am not a pro but this worked GREAT for me. Hope it helps.
May 18, 2008 | Pentax Optio S6 Digital Camera
Lens stuck
Solution:
The Lense is obviously jammed some how.
Suggestion:
Send the product back to the manufacturer and see if they can repair the product or send you a new one.
Dec 18, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Lens stuck out; camera won't stay on
I have the same problem. Its actually because the On/Off button got pushed in somehow and its stuck. At this time right now, im not sure how to make it unstuck, but sometimes it will stay on. But when you push on, since its being held down, its stuck that way and immediately turns off because its still being held down constantly. Maybe try using a thing needle to try and push it out?
Nov 13, 2007 | Kodak EasyShare M853 Digital Camera
Frozen camera
your lense is jammed try to put your finger in it and close the lense all the way it might me like hardly closed, i had that problem and now my is open all the way so i cant close it yuo can email me at minimacaluso@yahoo.com or im makaluso06
Jan 26, 2007 | Samsung Digimax S500 Digital Camera
Acer CP-8531 Digital Camera Logo
Top Acer Cameras Experts
Joseph Hoffmann
Robert A. Watson
Robert A. Watson
Are you an Acer Camera Expert? Answer questions, earn points and help others
