In device manager I have exclamation mark for network drivers. I cannot connect to the internet . Can I download new drivers
  • Eric Tao May 11, 2010
    Please specify your manufacturer and model
  • 62 Answers
What type of operating system you used, for some reason there is a compatibility mode for the appropriate OS. Is your network card built in on your motherboard? You can download SiS 190-191 v2.01 (free) for XP and Vista.
Posted on Sep 12, 2009
    President:
  • 1,179 Answers
Try uninstalling the network drivers from device manager & then reboot. See if Windows correctly identifies and installs network drivers for your hardware. If not you could use another computer and download the files from the network adapter or motherboard manufacturers website and save them on a thumb/flash drive and then install to your computer. Hope this helps.
Posted on Sep 11, 2009
  • 13,433 Answers
Right click on the problem device and select uninstall, after all the problem devices are uninstalled, right click and select Scan for hardware changes or to that direction, the devices will be reinstalled.
If there really is a problem the devices will report the same issue, right click properties and tell me what it says on the Status message of the device(s)
Device\NTPNP_PCI0027
Troubleshooting :
Cannot access internet in OS using onboard network card bg-country_outline_top.png bg-country_outline_bottom.png Solution
1. Please check the LAN settings in BIOS.
2. Install a fresh OS and the motherboard driver, network card driver in support CD or downloaded from official website.
3. If the network card is not recognized in Device Manager, please contact reseller (service center) for tests.
4. If the network card is recognized in Device Manager, please do some troubleshooting as the following steps:
4.1. If there is yellow question mark or exclamation mark before the network card, please re-install OS and drivers. If the problem persists, please contact reseller (service center) for tests.
4.2. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection, the network cable is shown as "un-plugged(X)", please check network cable/router/switch/modem/other network peripherals and network port, or plug network cable to other system for test. If the problem persists, use another computer in the same network environment to check if it can access internet. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable.
4.3. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is disabled (grey), please enable(right click and choose "Enable") it for a test. If the problem persists, please turn off firewall, search and kill virus, reinstall OS and drivers. If the problem still exists, please contact reseller (service center) for tests.
4.4. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is shown as "Limited or no connectivity" (yellow exclamation mark)", please do some troubleshooting as the following steps:
4.4.1. Right click and choose "repair"
4.4.2. Unplug and re-plug the network cable
4.4.3. Re-connect the network or access IP
4.4.4. Restart
4.4.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.4.6. Skip router and connected to Modem directly
4.4.7. Turn off other computers in the same network to avoid IP conflict
4.5. If there is no yellow question mark or exclamation mark before the network card, and there is no abnormal situation in Control Panel/Network Connections/Local Area Connection, please do some troubleshooting as the following steps:
4.5.1. Try to access IP or Static IP automatically
4.5.2. Unplug and re-plug the network cable
4.5.3. Re-connect the network or access IP
4.5.4. Restart
4.5.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.5.6. Turn off firewall, search and kill the virus, reinstall OS and drivers
4.5.7. Check MAC address ( You could follow the commands: " Start"-" All Programs"-" Run", please input " cmd", after that you could input " ipconfig/all" to check MAC address)
4.5.8. If possible, use another computer in the same network environment to check if it can access internet
a. If the network connection is OK in another system, please contact reseller (service center) for tests
b. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable
Mar 03, 2014 | ASUS SABERTOOTH Z77 LGA1155/ IntelZ77/...
Swann network card
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
http://download.cnet.com/realtek-rtl-gigabit-and/3000-2112_4-10278840.html
http://download.cnet.com/cnet-pro200wl-pci-fast/3000-2112_4-20682.html
hope this helps
Sep 13, 2012 | Computers & Internet
Speedstream 4100, can't download internet service cause pc there isn't any modem. The driver Intel R 82562V 10/100 network connection is missing and when i try to download it i can't get it. ...
make sure your its enabled in your bios
during the boot process you will see on your screeen to press acertain key to enter set up press and hold that key to enter set up
using arrow keys navigate to intergrated peripherals press enter look for SiS 10/00 press enter make sure ethernet its enabled
press f10 save to cmos
restrart your computer
if this fails to fix the problem
the driver for this modem should be on the motherboard disk or the disk provided by you ISP internet service supplier
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or
you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
also
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
http://download.cnet.com/intel-r-82562v-10/3000-2110_4-99324.html
http://download.cnet.com/intel-r-82562v-10/3000-2110_4-99289.html
hope this helps you
Oct 10, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
How can I install Compaq Network drivers when my internet is not working?
you will have to open up your network connections to check the state of your internet connection
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be fire walled
Make sure your isp provider is allowed in your fire wall settings
your network adapter might not work, and you do not have network connectivity or any related network functionality.
Device Manager may list your network adapter as not working and as not having a driver installed.
click start control panel administrative tools computer management device manager scroll down network adapters + expand Ethernet driver if you see a yellow ? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
the driver could be on the motherboard disk or the one supplied by your ISP internet service supplier or you might need to download it
http://download.cnet.com/realtek-rtl8139-family-pci/3000-2112_4-91313.html
if these arent right you will find network drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)but don
Sep 29, 2011 | Compaq Computers & Internet
My presario SR2170NX Cannot pickup Skype . The computer says my pcmci won't start I have a desk computer
Can you get an internet connection ??
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109025.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-pro-100-m/3000-2112_4-109029.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109002.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109004.html
if these packages are not the right
(be precise)don
Sep 26, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
Connect via wireless router, but when i click on internet explorer it says internet explorer cannot display webpage
this could be a driver problem or it might be firewalled
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
also
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
hope this helps
Sep 18, 2011 | Computers & Internet
I have CODE 10 on my Realtek PCIE GBA Family controller
code 10 no driver has been intalled for this device
if this is for an internet connection
the drivers might be installed properly for this device
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
http://download.cnet.com/realtek-rtl8139-810x-family/3000-2112_4-82823.html
http://download.cnet.com/realtek-rtl8139-810x-family/3000-2112_4-96337.html
if these driver packages aren
Sep 15, 2011 | Computers & Internet
My Motherboard Driver is Missing. Pls Send. Model Asus 845.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers or you might need to download one
http://download.cnet.com/%7Bvalue=http://www.download.com/cmi8738-c3dx-pci-audio/3000-2110_4-209129.html
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://download.cnet.com/%7Bvalue=http://www.download.com/lan-v94170-zip/3000-2112_4-147200.html
http://download.cnet.com/%7Bvalue=http://www.download.com/lan-xp-vista-v96310/3000-18492_4-147214.html?tag=mncol;2
hope it helps
Jul 12, 2011 | ASUS P4PE-X MB 845PE/ Audio/ LAN...
Motherboard P4i65GV ASROCK. Installed WIN XP service pack 2 , ethernet controller is not installed shows exclamation mark in device manager.Unable to connect to net.
you must ethernet controller driver first
goto device manager, right click at exclamation mark, then chose update driver, follow instuction step by step, if it ask for cd driver insert motherboard cd driver, if you did not have cd driver download ethernet controller here
http://www.asrock.com/MB/download.asp?Model=P4i65GV&o=XP
wait until process finish and exclamation mark at device manager disappear, and try to connect your computer to internet
i hope this helpful
thank you for using fixya
Feb 02, 2011 | Asrock P4i65GV Motherboard
Gateway mx3560 wireless (yellow exclamation mark) on device manager
Obtain an ethernet cable and connect to the Gateway Support site using wired network temporarily to download and install the proper wireless driver.
May 29, 2008 | Gateway MX3560 Notebook
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
