Question about True 12 cu. ft. / 340 liter Commercial Freezer T-12F
TRUE under counter FREEZER TU2-27F
Freezer will not freeze water, gets cold enough to freeze the top layer of water, but not all the way through. I've checked and topped off the refrigerant and have also cleaned the coils in the back. Any suggestions
will be greatly appreciated.
  • 40 Answers
Are both evaporator fan and condensor fan running?You stated that you topped off the charge.Assuming the charge is ok, the next thing to check would be the expansion valve.May not be metering the freon properly.A faulty expansion valve can trick you into thinking the unit is undercharged.It may be partially open and starving the evaporator.(Not freezing the water totally)You should have a even coating of frost on the evaporator coil when running.Hope this helps,let me know if i can assist you any further.
Posted on Dec 14, 2007
Freezer is not freezing
Good Morning Friend,
I understand that your Frigidaire freezer is not getting cold enough to freeze your food. I suggest cleaning the compressor, underneath your appliance, by using an attachment on your vacuum. I also suggest lowering the temperature and giving your freezer 4-24 hours to stabilize at that temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. If further troubleshooting is needed, please leave me the model number of your freezer. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire Freezers
Top 3 shelves don't freeze
Cold air sinks. If evaporator temp is not low enough only the items on bottom of freezer will get cold and possibly freeze - stuff on top will not.
Throw a digital thermometer in there towards the top shelves and I bet your temps are high. Low refrigerant will cause this; furthermore, if you leave the refrigerator door open by accident, the refrigerator will never shut off, the freezer evaporator will freeze over with a block of ice, and the freezer temps will be higher. If that is what happened, simply unplug the unit and allow it to self defrost and then turn it back on for proper operation and make sure that the refrigerator door is properly closed!
Nov 20, 2013 | Whirlpool Freezers
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
I have an AHT Salzburg chest freezer and it's stuck in "chilling" mode and not getting cold enough to freeze anything. It's a commercial freezer and says it has chilling and freezing modes but how do I get...
pull the plug and let it defrost. ck the drain for water. it maybe pluged. after 2 to 4 hrs. plug it back in and set the temp. to -10 degrees f . fill small dish or bowl with water and see how long it take to freez. if it takes longer then 4 hrs you may need freon or have a compreesor problem, or defrost timer .
Aug 23, 2010 | True 31 cu. ft. / 878 liter Commercial...
Not getting cold enough to freeze popsicles but is making ice cubes
water freezes at 32 degrees. ice cream needs to be below 0 degrees to remain firm. your freezer is nort cold enough. ;)
Aug 12, 2009 | Freezers
Our true freezer is not working at all.. No cold air going through the refrigerator.. Need repair assistance
we specialize in true freezer repair in illinois. Is compressor running or fan under unit? if not the thermostat may be bad.
Aug 06, 2009 | True 49 cu. ft. / 1388 liter Commercial...
My hotpoint under counter freezer isn't freezing properly
A freezer has a very simple operating design and there are only 2 customer serviceable components.
1. Make sure the cold control is set at the proper level.
2. Make sure that the door seal is making good contact with the cabinet. You can apply a thin coat of Vaseline to the door seal to help tight closure of the door.
Keep the door opening to a minimum during extreme heat conditions. Any small air leak can drastically reduce the operating norms during extreme heat conditions.
That's about all that you can do to regain control, the rest will have to be performed by a refrigeration tech. if you are still dissatisfied.
Jul 05, 2009 | Amana Freezers
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Candy fridge freezer
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 | Freezers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
True 12 cu. ft. / 340 liter Commercial Freezer T-12F Logo
242 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a True Freezer Expert? Answer questions, earn points and help others
