Question about Epson Stylus C88 InkJet Photo Printer
2 blinking red lights
I changed one of the colors in the printer and the door to the where the color is want close. I have 2 blinking red lights, can you tell me what I can do? The handbook was misplaced.
    President:
  • 4,402 Answers
First make sure you replaced with the exact same and that it is inserted all the way down and you took off all the plastic from the cartilage.
Posted on Dec 10, 2007
How do I replace a cartridge for the samsung clx-3175FN?
1. Open front door of printer
2. Each cartridge is colored coded to correspond to the toner color shown on the small dislay screen which displays empty or low toner for each color.
3. Remove that cartridge and replace with a new one. Make sure cartridge is seated in printer then close door and make sure it closes flush with the printer gbody otherwise the sensors will think door is open and not allow printer to operate.
If you are not using a samsung manufactured cartridge there is an additionl procedure o turn off the flshing red light on the front nel. Post another question if that is the case.
Jan 22, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Won't print, orange triangle with exclamation point
This triangle light blinking indicates that a door is open. Open the front access door completely. Close the front access door completely. Open the rear door and close it.
If this didn't fix it refer to this guide for all errors you get with this printer from HP website.
Dec 16, 2010 | HP LaserJet CP1215 Color Printer
The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
Hi:
If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
I can't switch my hp1560 printer on. A green light keeps blinking
it can be a problem with the cartridge
Just do one thing take out both the cart
Insert black one only and then close the door if it blinks then just take out the black cart and insert the color one and close the door and check if its fine or not
If its not blinking then its a cart issue
if its still blinking and cartriges are new its a definate problem with the printer
Oct 20, 2009 | HP D1560 Deskjet Printer InkJet
The ink light blinks all the time since I replaced the color
The ink light flashes when the top cover is open...check the switch that tells the printer when the cover is closed.
Feb 23, 2009 | HP DeskJet 842c InkJet Printer
How to change toners
Open front door, check on the color facing you, close door, press the color cartridge to advance the carousel to the color you need to replace, pull out the cartridge and replace with new one.
Jan 13, 2009 | HP Color LaserJet 2550n printer + HP Color...
Installing
not sure w/ this one, but is it blinking too fast on printer, the check color and black ink cartridges? and if yes what is the color of the light, is it yellow or red, and is the on and off lights, flashing?
-black and color blinking fast - install printhead
-black and color blinking slow - no cartridges installed
-on and off blinking black and color steady lights, calibrate
-hope this helps, or else contact kodak
-xoxo
Apr 11, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Epson Stylus C88 InkJet Photo Printer Logo
205 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
