Clean pump indication light on .how do i clean pump
    Sergeant:
    Champion:
  • 205 Answers
Dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Posted on Sep 11, 2009
Can not fine filter
Posted on Dec 16, 2012
F-27 light on
I assume that simply pressing PAUSE/CANCEL does not clear it. This indicator will come on if the overflow contact on the pressure switch is closed for more than 60 seconds. Is the drain pump running constantly with this indicator on? It should. If not maybe the pump is bad. If the drain pump is running then make sure that the inlet valve is shutting off the water. Does the indicator stay on even if the drain pump is working and you turn off the hot and cold water faucets? If not, then there is something wrong with the inlet valve. If so then I would suspect a bad pressure switch.
Jun 26, 2015 | Whirlpool Washing Machines
What looks like a curled yellow wire is flashing on the dashboard. After 5 mins of driving the engine cuts out and dies.
this engine heater glow indicator .this indicate if you have water with diesel inside the injection pump or if you have problem with brake light S.W can be check if rear light is ok on /off with brake and in this case engine will not cuts off .check fuel replace fuel filter if you can find injector cleaner is good to clean injection pump and lubricate to avoid injection pump noise and low pressure
Jul 13, 2011 | Volkswagen Passat Cars & Trucks
Brake light changed for audi a4 2001 but in warning light Problem
if hand brake indicate and flashing . means brake fluid need fil up on level . if heater light ( yelow)still falashing after replace brake light S.w check injection pump . in case if you vehicle still runing you can remove two line fuel and try feed with injector clean for few mint until water drain out from injection pump .
Jul 07, 2011 | Audi A4 Cars & Trucks
Dishwasher miele g646sc-the inlet/drain light flashes yet the drain system is clean and working the inlet filter is clean and the filter washed
Hi dear.If the checked lights comes on after the main wash & then flashes(when on main wash cycle,if the main pump works for a few minutes & then stops for a while & so on...)that indicates main wash pump faulty.You need to replace the motor it self.I hope that helps.Thanks.
Aug 25, 2010 | Dishwashers
Power shuts down
Sounds like a power supply issue.
If you call intex and tell they you have a power supply problem and a reciept within two years. they should ship you a new one.
Jun 23, 2010 | Intex '10 Saltwater System Pool...
Thumping noises and a belch when turned on. Will not start.
Judging from your description, I would check your installation and be sure that you have a good water supply. Then check the drain hose. The only things that can cause that are the pump motor and the drain motor. Judging from the parts list, the drain pump fails in those a lot. When the unit is first powered on, the drain pump comes on for a moment as part of the diagnostics. It may have something stuck in it or it may have failed.
Nov 20, 2017 | Bosch SHE4AM02UC 24 in. Built-in...
Clean Pump
The pump must be cleaned...u can call for the service technician.
Oct 13, 2009 | Washing Machines
I have a schaerer opal coffee machine, when I switch the machine on, the water light flashes, and a pump runs continuosly as if it is trying to purge the machine. but nothing comes through. does anyone...
I have a schaerer opal coffee machine, when I switch main power machine on, the descaling indicator, cleaning/rinse indicator and stand-by mode indicator lamp remains lit, and a pump runs continuosly. the machine do not ready mode indicator. Yudi INDONESIA
Apr 05, 2009 | Schaerer Opal Espresso Machine
My washer gets so far then says fp
fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
1,039 people viewed this question
Top Washing Machines Experts
